| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | hey guys. OK, here is what I got: 1957 truck dual 1bbl Carter W-1's on a 235cui. Fenton setup. Everyday on initial start-up, just hit the starter and she turns right over and runs like a top. But, after running her around town for a bit and I get back in to start her, she eventually starts, but she is flooded. Much more revolutions till she kicks over than when she has been sitting for a while. I'm flooding...right? If yes, solution?  | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | thanks for the tip. That write up was very informative. So, basically this is just something I have to deal with, and is 'normal'. Still I wish there was another way. Oh well. I'll put up with it. My straight 6 dual carbs are worth it!!  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You might have too much fuel pump pressure. Check the pressure & if so put a regulator on it. The heat might be causing the fuel to boil. You might need insulators under the carbs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | I have been dealing with the same issue with three carburetors, Starts right on cold engine, and after it sets for a hour, its the 15 minutes stops that it won't start. I have tried lowering the floats, but that leans it out where it duns like crap, I have a regulator set to 2 psi fuel pressure, and tried the isolators under each one. Nothing really helps much other then setting them lean. I learn to live with it. Not hitting the throttle helps, but its not the cure. Once started it runs great so I don't worry about it.
Good luck with yours, Joe. | | |
