| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | My '56 3600 dually has 17.5 inch budd style wheels held on with standard heavy 1/2 20 flat nuts. I've been looking at these heavy hex stainless steel 18-8 nuts for replacement. http://www.mcmaster.com/#stainless-steel-hex-nuts/=7ce40p.your thoughts? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You should have a tapered side wheel nut. I haven't seen these in SS and when I go to the page you reference and use the locater I could only bring up 1/4" size. Replacing a standard hex nut with another makes no sense to me. Use the right parts. Any tire store or auto parts should carry them so get their advice. I don't think the Budd style wheel use anything different. | | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | Thanks for the reply these wheels use a standard heavy hex nut, no taper. I guess the question is would the SS be to soft. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Just as with regular steel there are different kinds of SS so it will depend on the material. Again I would recommend a good tire source for this kind of question. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Standard stainless steel in strength is equivalent to Grade 2 and would never be used in conjunction with brake or suspension parts,wheels included. Grade 8 stainless is available, but as Dave suggested, it would be a very good idea to talk with a good tire shop.
Drew
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Any chance you could put a stainless steel cap over the standard nut? Any good truck stop display rack has them.
Joe | | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | Talked to NAPA and two tire stores and my brother the engineer and the all said it would be ok using 18-8 SS. One of the tire stores had some for $4.00 ea,just got them from Mc Master for $1.05ea.Very shiny, no need to buff. The SS caps were $1.94 | | |
