1 members (1 invisible),
78
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | I goofed and posted this question under welcome center. Can anyone tell me what will happen if the bedwood doesn't have a channel routed in it for the wear strips to fit in? Can they just be bolted on top of the wood? Will the fender wells of my fleetside bed fit without the channel?
Thanks for your help. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I think the wood will migrate around, possibly leaving gaps big enough for the strips to fall between the boards. The edge isn't routed, a table saw will do the job (I did with mine). Somewhere on this site the dimensions are available. Each side must be run past the blade twice, once to knock the top down about 1/8 inch and once to make the slot about 1/4 inch deep and 1/4 inch from the edge. Sand smooth and finish... You're done. Absolute precision isn't necessary, but find the correct dimensions to start.
Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | Thanks for the info. I thought that could be the problem if the channel was not put in the wood. In your reply you said to use a table saw, if I don't have one but have a router and blade to use do you think I could make it work? I see you are also a british car nut. I got bit by that bug at a young age and can not seem to shake it. | | | | | Joined: May 2010 Posts: 2 New Guy | | New Guy Joined: May 2010 Posts: 2 | Does the bed have to be removed to remove and replace the bed wood? I have a 2nd series 1955. Thank You
Thanks John Sobota | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Does the bed have to be removed to remove and replace the bed wood? I have a 2nd series 1955. Thank You It might be possible to do the job with the bed more or less in place. You still would have to get it up off of the cross supports, though. I pulled my bed off and had it on saw horses. It is a lot easier that way if not absolutely essential.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, the bedwood can be serviced with the bed still on the truck.The inner boards can be removed without any issues once the skid strips are removed, and for 2 of the boards, the bed to frame mounting bolts. The 2 outside boards will require the bed to be raised a bit for clearance, but is not hard to do. I lifted the bed enoung to take mine out with no assistance (I will admit, I'm not a small guy, 6'4" 284#). Have a few peices of 1 by boeards handy to slide under the angle strip once you take the bed board out to support the bedside. Place the 1 by over the cross sills. When i did mone, it was stable enough that I could drive the truck without them comming out, however, I would not advise going very far like that.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 2 outside boards will require the bed to be raised a bit for clearance, but is not hard to do. I lifted the bed enoung to take mine out with no assistance (I will admit, I'm not a small guy, 6'4" 284#). I'm not nearly as big and strong as he is. I have used my cherry picker to lift beds and find it an easy and manageable job solo.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I had a steel floor in my box, I wanted the look of wood. I built the whole thing on 2 sawhorses and slipped it onto the floor, Sunk 4 stainless bolts thru the whole thing and it looks great. Mar Kay had it on their site for awhile. I used their stainless strips. Now if I Want to I can just slide it out for refinishing | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Hi Blue
If you want to use a router, a dado bit should be good for the first pass (lower the edge) and a small channel bit could make the slot. If you're handy with a router, it should come out well. I did my bed with it still on the truck, but I lifted it with a hoist. I also used cheap shelf wood that I cut to size, milled, stained and finished. I decided to put the bed bolt heads under the wood, rather than fighting with recessing the offset washers.
I sort-of inherited the British car bug. I was the only one who wanted to try to restore the car after my father passed. Since then I've acquired an 86 Jag XJ-S V12... Isn't pulling out your hair sooooo much fun!
| | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | I'm going to try the using a router, should come out ok. Got my wood from our Jr High industrial arts teacher. I'm using Cyprus, it's not a hard wood but is very resistant to rot. Don't plan on using this truck to haul much anyway.
I've got a 69 MG Midget that our local votech finished body work and painting for me about 3 weeks ago. It isn't perfect but it sure looks better than if I'd tried painting it. It's going to be fun putting it back together I've had it apart for 5 years. | | | | | Joined: May 2010 Posts: 2 New Guy | | New Guy Joined: May 2010 Posts: 2 | Thanks for the help guys. Lets see how far I get this weekend!
Thanks John Sobota | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Jim Carter has a book "Bed restoration manual" that tells how to prepair your boards and how to do just about everything. It is well worth the money. It even tell what depth to cut the groves.
Monroe McKill
