8 members (WICruiser, Southerntruck, jaycoop, 42465967, 2-Ton, Shade Baby, Joe H, TUTS 59), 127 guests, and 2 robots.
Topics128,129
Posts1,056,362
Members48,441
#651442 06/01/2010 5:08 PM
My '56 3600 dually has 17.5 inch budd style wheels held on with standard heavy 1/2 20 flat nuts.
I've been looking at these heavy hex stainless steel 18-8 nuts for replacement.
http://www.mcmaster.com/#stainless-steel-hex-nuts/=7ce40p.
your thoughts?
You should have a tapered side wheel nut. I haven't seen these in SS and when I go to the page you reference and use the locater I could only bring up 1/4" size. Replacing a standard hex nut with another makes no sense to me. Use the right parts. Any tire store or auto parts should carry them so get their advice. I don't think the Budd style wheel use anything different.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks for the reply
these wheels use a standard heavy hex nut, no taper.
I guess the question is would the SS be to soft.
Just as with regular steel there are different kinds of SS so it will depend on the material. Again I would recommend a good tire source for this kind of question.
Dave
Standard stainless steel in strength is equivalent to Grade 2 and would never be used in conjunction with brake or suspension parts,wheels included. Grade 8 stainless is available, but as Dave suggested, it would be a very good idea to talk with a good tire shop.
Drew
J Online: Content
Any chance you could put a stainless steel cap over the standard nut? Any good truck stop display rack has them.
Joe
Talked to NAPA and two tire stores and my brother the engineer and the all said it would be ok using 18-8 SS.
One of the tire stores had some for $4.00 ea,just got them from Mc Master for $1.05ea.Very shiny, no need to buff.
The SS caps were $1.94
