Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, tclederman, Youngin' Tut 59, UtahYork, Woogeroo), 37 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#650765 05/29/2010 9:10 PM
Riding in the Passing Lane
What is the best way to remove add on window tint. My truck looks like a blackout.
George
1972 Chevy c10 Cheyenne Super
Well, I don't know the best way. I have removed that stuff a couple of times. They only wat to effectively remove it is with soapy water and a razor blade. Score the plastic with the razor, spray on the soapy water, let it set, and scrape the stuff off. I have thought about trying a heat gun, but never did. The glue on the mylar is water activated plus the mylar is designed to set in the sun for hours on end. So I don't know if heat applied from the insede would do any good. I hope this helps, Jimmie.
Jimmie D #650770 05/29/2010 10:01 PM
I removed some on a vehicle my son had. The tinting material didn't have the proper decal on it deeming it the correct shade and as my son started trying to take his driving test in it, the person of authority told him he can't take his driving test in it until either the tint was certified or removed. I removed it. The tint came off easy, but I had to wash down the window with lacquer thinner to get the glue off. What a mess!!
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I had to remove the tint from my son's truck.
Tint came off easily once I got it started.
BUT it took spraying WD-40 on the glue to get it off.
Spray it on & let it set for a minute or two & then take a razor blade to it.
Prepare to spend some time w/it because it isn't going to just fall off....joe
wrenchbender
I have used a heat gun & a razor to get the film off.
Ijust held the heat gun in one spot over the film for about two or three seconds& then scraped that spot with a razor to get it stated & then I peeled it off by hand as much as I could & the do the same thing over again &that seemed to work ok for me.
Hope this helps
Roge
roge #650858 05/30/2010 6:48 AM
The preferred method we use at work is the hot air gun,glass cleaner and a fresh new razor blade to remove the glue residue.
Just a point though,if your glass is laminated,don't overheat the glass too much,or burn your fingers!
Depending on the quality of the tint it is possible and if you don't pull too hard,the film and adhesive will virtually come off intact.
More pix on Flickr.
jockbolter50 #650867 05/30/2010 9:13 AM
Hey John- Jimmie D made a good point: If sitting in the hot sun all day won't affect it, why does a hot gun?
You are the professional. I await with bated breath.
Not really. But it'd be nice to hear your answer.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Davey Do #650956 05/30/2010 8:12 PM
Dave,I suppose it could be peeled whilst sitting in the hot sun,but you would still have to initiate the peeling.
Remember though,I live in the west of Scotland. brrrrr
We use a hot air gun,simply because you can concentrate the heat in a fanning motion as you pull the film from the glass,you just have to be careful not to overheat/melt any surrounding plastic/rubber trims etc,asbestos fingers help too!
More pix on Flickr.
jockbolter50 #650990 05/30/2010 10:47 PM
Auto Zone sells a tint removable spray.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #651056 05/31/2010 3:58 AM
...I "scratched" the film some with the razor, squirted some Glass Plus window cleaner on it and it came off fairly easy. It probably depends on how well it got put on as to how it comes off or how long its been on the glass?!
Achipmunk #652382 06/04/2010 9:21 PM
I got it off. Thanks guy's. They even had it on the inside of the windshield. That was the hardest part of it.
