| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What is the best way to remove add on window tint. My truck looks like a blackout. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Well, I don't know the best way. I have removed that stuff a couple of times. They only wat to effectively remove it is with soapy water and a razor blade. Score the plastic with the razor, spray on the soapy water, let it set, and scrape the stuff off. I have thought about trying a heat gun, but never did. The glue on the mylar is water activated plus the mylar is designed to set in the sun for hours on end. So I don't know if heat applied from the insede would do any good. I hope this helps, Jimmie. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I removed some on a vehicle my son had. The tinting material didn't have the proper decal on it deeming it the correct shade and as my son started trying to take his driving test in it, the person of authority told him he can't take his driving test in it until either the tint was certified or removed. I removed it. The tint came off easy, but I had to wash down the window with lacquer thinner to get the glue off. What a mess!!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I had to remove the tint from my son's truck. Tint came off easily once I got it started. BUT it took spraying WD-40 on the glue to get it off. Spray it on & let it set for a minute or two & then take a razor blade to it. Prepare to spend some time w/it because it isn't going to just fall off....joe | | | | | Joined: Aug 2006 Posts: 18 New Guy | | New Guy Joined: Aug 2006 Posts: 18 | wrenchbender I have used a heat gun & a razor to get the film off. Ijust held the heat gun in one spot over the film for about two or three seconds& then scraped that spot with a razor to get it stated & then I peeled it off by hand as much as I could & the do the same thing over again &that seemed to work ok for me. Hope this helps Roge | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | The preferred method we use at work is the hot air gun,glass cleaner and a fresh new razor blade to remove the glue residue. Just a point though,if your glass is laminated,don't overheat the glass too much,or burn your fingers! Depending on the quality of the tint it is possible and if you don't pull too hard,the film and adhesive will virtually come off intact. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Hey John- Jimmie D made a good point: If sitting in the hot sun all day won't affect it, why does a hot gun?
You are the professional. I await with bated breath.
Not really. But it'd be nice to hear your answer. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Dave,I suppose it could be peeled whilst sitting in the hot sun,but you would still have to initiate the peeling. Remember though,I live in the west of Scotland.  We use a hot air gun,simply because you can concentrate the heat in a fanning motion as you pull the film from the glass,you just have to be careful not to overheat/melt any surrounding plastic/rubber trims etc,asbestos fingers help too! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Auto Zone sells a tint removable spray.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I "scratched" the film some with the razor, squirted some Glass Plus window cleaner on it and it came off fairly easy. It probably depends on how well it got put on as to how it comes off or how long its been on the glass?! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I got it off. Thanks guy's. They even had it on the inside of the windshield. That was the hardest part of it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
