5 members (Ponchogl, MickeyP, Bill Marlow, 48jim1ton, 1 invisible), 119 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
I removed the 3 speed tranny off my 1950 1/2 ton to get to the clutch. I didn't notice anything wrong with it to begin with but how do you tell if there needs to be a rebuild or repair? Would you see fragments of metal once you open the shift cover? Is there something I should be checking before I put it back? I just want to make sure I take care of any problems before putting it back together.
Does that mean you were driving it and had no problems? Now is a good time to open it up and inspect for worn parts but if it was AOK before then a gear oil change is probably all it would need.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
It worked before, it was the clutch that failed. It looks pretty good from the quick inspection without really good light. I will give it a better look this week. Should there be any play in the shaft or should it be tight/solid?
There should be very little play in the input shaft of a good transmission. I'm certainly no transmission expert, so hopefully someone better qualified will speak up.
1953 Chevrolet 3600
