2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | I removed the 3 speed tranny off my 1950 1/2 ton to get to the clutch. I didn't notice anything wrong with it to begin with but how do you tell if there needs to be a rebuild or repair? Would you see fragments of metal once you open the shift cover? Is there something I should be checking before I put it back? I just want to make sure I take care of any problems before putting it back together. Thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Does that mean you were driving it and had no problems? Now is a good time to open it up and inspect for worn parts but if it was AOK before then a gear oil change is probably all it would need. | | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | It worked before, it was the clutch that failed. It looks pretty good from the quick inspection without really good light. I will give it a better look this week. Should there be any play in the shaft or should it be tight/solid? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | There should be very little play in the input shaft of a good transmission. I'm certainly no transmission expert, so hopefully someone better qualified will speak up. | | |
