3 members (Otto Skorzeny, WICruiser, TUTS 59), 96 guests, and 2 robots.
Topics128,093
Posts1,056,478
Members48,444
#648209 05/20/2010 11:08 PM
I was wondering if anyone can tell me if taking my 283 out of my 65 Chevy C10 and putting in a 400 in its place is going to be a problem? I am not sure if I need to use a different radiator or cooling system. Is this going to be a "CAN O WORMS?" or is this a okay swap? Thanks for any help.
I think it would be okay. You may find the accessories all mount different, but the motors are essentially the same externally and will fit in the same spot.
I would expect the 400 to possibly require more radiator.
the 400 is externally balanced so the balancer and flywheel/flexplate have to be balanced. It's a specific to the 400 thing,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I had a 283 in my old '63 C10. I swapped in a 1974 400 in 1982. I had no trouble just bolting it in. everything matched up and went in with no problems. I didn't even have any cooling problems using the stock radiator from the 283.
Like 48BigTrucks said, you MUST use the flywheel/Flexplate from the 400 because they are externally balanced. That's the only difference you will need to worry about.
I assume you have the entire 400 engine with the heads it came with. Reason: you cannot use stock 350 heads, unless you drill out for steam holes in the 400 block. You may need a new radiator and definately a fan shroud, since the 400's tend to run a little warmer. Other than that, it's a good swap.
