7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#647395 05/18/2010 3:38 AM
Can the inner fenders on an AD truck be installed on the truck without the outer fenders attached or must they be installed bolted together as an assembly? I have some wiring to finish up and I didn't want to be leaning across a newly painted outer fender. The hood is not on yet.
Weeds
Weeds #647396 05/18/2010 3:40 AM
Yep, just leave everything loose so you can make adjustments.
oldcarandtrucknut #647467 05/18/2010 12:50 PM
Thanks oldcarandtrucknut.
Weeds
Weeds #647790 05/19/2010 2:16 PM
Weeds,
..yup that is how I did mine ...i bolted on the inner fenders an radiator support ...an it was easy to hang the fenders ..finish painted by myself, I used lottsa blue painters tape ..but hung my fenders at 2:00am by myslef.
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #647821 05/19/2010 5:46 PM
SW radial, I am going to use your and oldcarandtrucknut's method to assemble the front end sheet metal. How did you know how much to shim up the radiator support or did you just guess at it? I have heard it said to hang the hood first and also to install the front clip as a unit. At 2:AM my brain has already shut off so I will be doing it in the daytime. Thanks for the advice.
Weeds
Weeds #647893 05/19/2010 10:48 PM
Yeah, must have the hood fitted to the cab first. Then fit the fenders/adjust radiator support to line up with hood. Kinda tricky. One thing I found out, if your cab mounts are a little out of whack, it screws up how your front sheet metal adjusts. I had to shim the crap out of the cab to get the front end to line up decent.
Weeds,
I used a chunk of 1/2" thick belting from a junk conveyor at work to make my radiator support pads ...it werked pretty good.
It si NOT PERFECT but acceptable.
Tim
1952 Chevy Shortbed
SW_Radial #648269 05/21/2010 3:04 AM
Weeds... I ask the same question some time ago about "shimming" under the radiator since it seems everyone, at least at that time, were having to raise it up..... so I thought why not do it to start with. The answers back then leaned toward going with what was there original.... if you think the new pieces are exact duplicates!!!????
Tim is on track with the conveyor belt. I have used a lot of old FIRE HOSE under many things on my vehicles. Its tough, has two or three diferent layers and some volunteer fire dept may have and old one laying around. I used it on my panel and it works well especially with the polyester(?) outer layer which will never rot....or not in our lifetime!
