0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#645537 05/11/2010 11:07 PM
for those of you running small block chevys in your ad trucks, are you using short or long water pumps?
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Short.
The 350 'vette engine I got had a short pump thankfully, even then it's tight!
More pix on Flickr.
Long has more accessory options but the short is historicly correct until 68.
long on mine
Is it true that if you can slide your fingers between the pump and the block, you have a long pump??
From what I've read, yes thats true. Never tried it though. I've got a short one. If you try it let me know. I'd like to know if its true too.
H Online: Content
Long-offset pumps are there to accomodate the relocated timing marks on the cover- - - -about 12:00 instead of the earlier 2:00 position. Be sure the pump, timing cover, and harmonic balancer are off the same-vintage engine. A mismatched timing cover and balancer will result in ignition timing that's impossible to adjust properly with a timing light.
Riding in the Passing Lane
The short pump is almost touching the timing cover. The long pump has about a 1/2 in. gap.
1972 Chevy c10 Cheyenne Super
gazim #647054 05/17/2010 12:46 AM
I guess that would depend on the size of you fingers Gary... grin ..I have a long one on mine and yes I can get my fingers pretty much between them....dave
1949 Chevrolet 3100
correct on cars up through 68 but used on trucks through 72.
Evan
Thanks Dave andguys.
