0 members (),
125
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64648 08/21/2006 5:57 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | First of all this is a SBC 305 v8 with a/c and power steering... im getting a ticking sound when my a/c compressor kicks in. as soon as a/c is turned off the ticking stops. driving me crazy... any ideas? no noticeable vibration occurs when the compressor kicks in. i have looked and can not seem to locate the problem. | | |
#64649 08/21/2006 7:37 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | if it just does it when you turn it on its the compressor clutch "kicking in" or engaging so it will cool. Depending on model and insulation etc some appear louder than others. Mine on my 2000 silverado is getting louder as it gets older!!! | | |
#64650 08/21/2006 7:46 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You might add a 2 oz. can of oil charge. Make shure there is sufficant freon in the system. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#64651 08/21/2006 7:47 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | yes its only when the clutch is engaged. and stays on the whole time the clutch is engaged... turning off the a/c or turning down the "cool" untill the clutch disengages will make the ticking sound stop... | | |
#64652 08/21/2006 7:50 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | good idea wrench. i just replaced my condenser and dryer and asked the guy at the a/c parts shop if i should add anything else but he was busy and may have forgot to mention. there is only about 1 - 1 1/2 of the small cans(12 or 16oz) of r134 in the system. | | |
#64653 08/22/2006 3:11 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The R-4 compressors are prone to do that. I got a warrantied compressor from a GM tech to replace my locked up compressor, that's all that's wrong with them is that they "tick". Other than that, it works great, Scott | | |
#64654 08/22/2006 3:32 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Take a solid bar and put to ear and item making noise while noise is present.It's more than likley a valve that is noisy in the compressor.Like a Dr's stethescope, I use this method to find all kinda engine noise's,from rod bearings to valve /lifter sounds. | | |
#64655 08/22/2006 6:46 PM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | TROY DESTROY After changing out the condenser and dryer did you add any oil to the system this system should hold about 8Oz of oil a good cummpressor should make a whiring sound not a clicking sound usually after a while the click will turn to a knock and then you end up with black death. What color was the inside of your old parts clean or a black dirty color | | |
#64656 08/24/2006 6:03 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | old parts had clean oily fluid leaking from them. I fixed this at an a/c parts supply in the parking lot. had the old guy help me fill the system afterwards with his manifold. asked him if anything additional was needed... he said system should still have enough oil in it. | | |
#64657 08/25/2006 4:03 PM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | TROY old parts had oil leaking from them !!!the receiver drier holds a good part of your oil a few ounces and he said should be? any time a major part commpressor, coils, or dryer is changed oil should be measured to make sure there is enough in the system. your truck holds 5 quarts of oil do you drive it when it has only 2 in it? | | |
