| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 16 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 16 | My 1961 Apache is original and has developed rust in the gas tank so badly that it clogs the cloth strainer on the pickup tube in the tank. Can it be vatted like a radiator with compromising the crimped seal? Is there a better option to remove the rust and treat the tank? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, they can be cleaned and coated inside to seal them, check with your local rad shops, one will do it
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If a new one is available it is much better to just put in a new one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Go new and never look back, Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Finding a shop who still vats radiators is getting to be a task. I went to several local ones and most do not even have a vat anymore. The one I found who did wanted $50 bucks to vat my small panel tank overnight. I told him Jesse James carried a gun when he robbed folks and I left..... Bought a new and as Scott says "never looked back". | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | bought a rust clean out kit for a honda 3 wheeler gas tank and it worked great, got it at a motorcycle shop, came with a rust destroyer, drying agent and sealer.... | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | To me, rust like you mention would mean that there is a part of the tank that is rusted badly and as a result the metal is thin at that point. I would not fool around with a weak rusted tank. | | |
