9 members (Wayne67vert, TooMany2count, Nick in Manitou, NJC, Mike in Sycamore, Bill Hanlon, Ponchogl, sron48, rfs56trk), 85 guests, and 4 robots.
Topics128,137
Posts1,056,747
Members48,454
#644070 05/06/2010 6:33 PM
Just bought the rubber L-shaped gasket with a slight groove on the backside. How in the world does it fit? The cowl vent has an inner lip/trough that drains the water and an outer trough that I assume holds the gasket.
That said, does the L or leg butt against the intermediate, vertical flange? Then the the "back with groove" squashes against the bottom of the outer trough and up the outer sidewall?
This is what I tried and the rubber appears to have to be stretched considerably. You need several hands to pull it around the intermediate flange. Do I use adhesive glue? I'm thinking it will just bounce back over the flange.
Anyone experience the pleasure of popping one into place? Pictures?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
MMMMM, something seems fishy? Most of them just fit around the "lip" and lay pretty good. It should practically only lay one way. Yes, when you put it down I'd use a little weather stripping on it to keep it in place.
old truck heaven
old truck heaven
Hi: There are two types of these gaskets commonly used for the cowl vent.
The die cut sponge rubber is my favorite. It lays in the trough with weatherstrip cement under it.
They type you have fits in the same way...although not that easy to get it in there. The best is to take out the cowl vent piece, cement the rubber in and reinstall the cover....I di one of my 7 trucks 1941-46 that way...after that I now have only used the foam.
Well my cover is off so it's already easier to work on. I'll try some 3M cement. Maybe it won't keep pulling off at the corners and lay down at the V's in the middle.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
