2 members (55shaker, 1 invisible), 75 guests, and 4 robots.
Topics128,185
Posts1,057,281
Members48,467
#642687 05/02/2010 12:12 PM
24601
24601
Well, after missing the Winchester parade (again) and the Mechanicsville VFD Parade this weekend because we just haven't been able to get the truck to even start (let alone run), we've made the big decision to pull it out of service and remove the drive train.
Out comes the 305E V-6, SM-465 and both axles. Back in goes the Detroit 4-53T, RT-610 Road Ranger and the Dana 80 rear axle (with disc brakes).
We already have most of the components on hand. And I will be sure to take pics as we go along.
Wish me luck in getting further on this than the last time ... wink
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
V
V Offline
I am envious of that drive train swap. The thought of breaking 45 mph going down the road cool
V
V Offline
We missed you in Winchester. Good luck with the drive switch over!
Sorry you continue to fight with the fire truck. Good luck with the swap.
John,
I sure am puzzled to why you are still having problems with the V-6 (unless I missed any new updated info on it), but that will be one cool truck with the Detroit along with the Road Ranger.
Keep us posted.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
.....good luck John.
Hey John,
Not trying to rain on your parade, but wouldn't it be a lot easier to swap in a 350 SBC? The existing transmission, rear, clutch and brake pedals could be reused, it might be a whole lot less fabricating. The SMC should line up with the pump also.
Will the DD have enough rpm to spin the front mounted pump?
Just thinking ahead... headscratch lol!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
You can't blame me for it this time!
GMC: Get More Cash...
1958 GMC
My Webshots photos
That ought to make an interesting and fun toy! thumbs_up
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
24601
24601
Thanks fellas -- I appreciate everyone covering my shifts while we're out of service smile
Mike B -- A 350?? Aren't *you* the funny one. Seriously, a 350 would probably bolt in but I have a 4-53T and the RT-610 that both need a job. We took some measurements last weekend and it appears to require minimal fabrication or modification -- at the most, we'll need to swap out the tranny cross member. We might have to do some banging on the inner fenders. I still have dibs on that front axle of yours, right?
According to Leid's, the 4-53T idles about where the 305 does (~500 rpm) and the pump maxes out around 2,500 RPM which is where the 4-53T cruises, so I think I'm good. Remember -- that pump was designed to be driven by a babbited 235.
Dave -- Not your fault.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
John,
Not saying it wouldn't be cool and all, just thinking about down time.
I was thinking about all of the little things that make it a pain to do a swap like pedal linkage, exhaust, steering, will the engine crank be at the same height to line up with the pump... etc. dang Bolting the engine and trans in is the easy part.
Front axle is still yours...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Moderated by  69Cuda
