3 members (Gdads51, Gray_Ghost, klhansen), 116 guests, and 3 robots.
Topics128,161
Posts1,056,957
Members48,458
Despite its good qualities I would like to exchange the oil bath filter for a conventional style with a filter. I have seen the little ones offered by many suppliers but is there something a bit larger in diameter? Something about 8 inches?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
This subject came up here maybe a week ago. Believe you can just pull the guts out of the oil bath and replace with a modern paper filter and slap the lid back on. As to the correct size, don't know. Search posts from last week or someone will come along that knows.
1946 1/2-Ton Chevy
If you do the "conversion" method I would find another used one to gut and clean up and use. Retain the other in it's original state.
Jim Carter sells a chrome air cleaner for about $30. I had some - they work fine but the look did not grow on me (I am back to oil-bath or oil-bath conversions).
On the same age, he also sells a nice reproduction for the standard-equipment spark-arrestor style air-cleaner.
I replaced my entire oil bath element with a Fram CA148. Fits great!
Ed
I guess I should have been more specific when I said I wanted to change. I want to replace the entire unit for something a bit 'sportier' for want of a better word. I am a firm believer in oil bath filters but my driving conditions and mileage don't warrant that type. I would not alter my existing unit as it is in mint condition.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Apprentice
Apprentice
How in the heck do you replace the element? I took mine off the other day to clean and refresh the oil. My element is original and a mess inside from what I could see. Being my first oil bath and original gear; is this supposed to be replaced / cleaned at some point? Hmmmmmmmm
