4 members (KEVINSKI, Nick in Manitou, FishinToms53, mick53), 74 guests, and 2 robots.
Topics128,126
Posts1,056,353
Members48,441
#637916 04/15/2010 3:32 PM
I have tried and tried and tried to get my front right brake from grabbing too quickly, and pulling to the right, but still am having a problem. Any idea on how i can get the brakes to grab evenly? I have replaced and/or rebuilt all of the components in the brake system, short of the foot pedal. All of the lines have been replaced as well. I have bled them several times and have also adjusted them as the maintenance manual calls out. All of the front end steering linkage is tight. Any help would be appreciated. I know swapping to disk brakes would be ideal, but on a budget, it's not an option.
Fix the left brake, that right one is working fine.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Ditto
Robert C.
I'm a Genius in the making.
1950 3600
That's what I was thinking also.
Brian
1955.2 3100 Truck
Cut both drums equally, to the same inside diameter,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
Riding in the Passing Lane
Make sure the drums are the same dia or near like Scott say's. Check the linings to see if they may be loose at the ends. Take a rough file or grinder & put a champher on the edge of the linings. Sometimes the sharp edges dig in. Wear a respirator when you do this. They may contain asbestes.
1972 Chevy c10 Cheyenne Super
Did "all the lines" include the flex hoses?
1951 1 Ton Completed
Hi, check the tie rod ends for play and the rear leaf spring bolts( the ones with grease nipples) for wear.Also in the rear of the leaf spring there is a brass bushing, check it to. Check my post in engine & drive shop under brakes lock up.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
hippy #638193 04/16/2010 1:11 PM
Shoes are not expensive, might be worth trying a different brand.
Thanks all for the advice, i appreciate it. I guess i'll work on it this weekend and see how things turn out.
I'm not sure of the old trucks...
but if the shoes are put on wrong...(short shoe to front, long to back is the proper way) you will have problems....
check the adjustments, bleed the brakes, check front end for excessive play.....usual suspects....
GMC: Get More Cash...
1958 GMC
My Webshots photos
Section 5-18 in the Shop Manual is important, be sure to perform this step effectively.
