| | | Forums66 Topics128,110 Posts1,056,246 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 31 Apprentice | | Apprentice Joined: Mar 2010 Posts: 31 | saw a post awhile back about get brake shoes relined. ive never heard of doing this.is it cheaper then buying new shoes and if it is were can i get it done at,i have a stock 53 3100 | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You can buy the reline kits, I have seen them on ebay and they may be available from the stovebolt sponsor vendors. See the stovebolt home page. The tools needed are a good ball-peen hammer and a special rivet punch and your handy dandy bench vice. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 1/2 ton relined shoe sets are readily available. Sometimes the larger trucks sets are hard to find. You can take the shoes to a brake shop that does this & have them relined, or put the linings on your self like Tmater says, but it's cheaper & easier to buy relined sets. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 31 Apprentice | | Apprentice Joined: Mar 2010 Posts: 31 | Thanks guys im going to look around to see where i can get new relined brakes.I just heard about relined shoes and thought if it was cheaper id try it out. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can get them at NAPA. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | try NAPA.avoid the dust an the rest of the problems.used to do that in auto shop,50 years ago.shoes have too be ground to right angle +trimed.press for the rivets.easy job,but where do ya buy the equiment these days to do the job??? for 1 brake job
dan-pa
| | | | | Joined: Mar 2010 Posts: 3 New Guy | | New Guy Joined: Mar 2010 Posts: 3 | There is a company in Houston Tx. They re-line any type shoe and i mean any size. You will have the choice of bonded or riveted. I had a pair of 14"x 2-1/2" Dodge shoes re-lined/riveted for $18/ea. There name is The Heitman Company Inc. 1422 McCarty, Houston Tx.77220 ph# 713-675-9001 fax# 713-675-0519 www.heitmancompany.com Houston is a truck lovers dream. There are so many specialty shops for trucks its unreal. This company does excelent work. I hope this helps: Nick Mopar | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 1953mn, don't forget to look around for shops in your area that supply the tractor trailer shops. Go by a shop and ask who is doing their relines. I worked at a transport shop once and we sent our shoes to a place in Charlotte, N.C. They could do about anything like Nick Morpar is talking about. There should be one in your area, or close by that does the same thing? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Bob Adler writing in Vintage Truck some years back advocated the use of thicker linings rather than turning the drums any more than is safe. I believe he had a company in Rochester NY do the work. | | |
