Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (46 Texaco, Shade Baby, FAST55, Pete O), 145 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
are there any cons to running cruise on a carbarated motor
just finding a cruise unit that works with a carb. They probably aren't made anymore.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Google "aftermarket cruise control". You should find something. I was looking not too long ago for one for a 76 motor home... 454/4bbl. No mention on the websites that FI was required.
In the end, didn't need it, so I have no experience with the install or anything.
Years ago I put an aftermarket unit on a Chevy Bel Air I had. It had magnets that were fastened to the drive shaft, and a sensor that mounted near them. There was a servo unit that went under the hood, with a cable that hooked on to the carburetor linkage.
I'm sure you'd have to look a bit to find such a unit today, but I'm sure there's one out there somewhere. It can be done.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
that dakota looks promising thanks
