7 members (Peggy M, RoadsScholar, dt235sd, Otto Skorzeny, Bill Hanlon, cmayna, 1 invisible),
145
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | are there any cons to running cruise on a carbarated motor | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | just finding a cruise unit that works with a carb. They probably aren't made anymore. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Google "aftermarket cruise control". You should find something. I was looking not too long ago for one for a 76 motor home... 454/4bbl. No mention on the websites that FI was required. In the end, didn't need it, so I have no experience with the install or anything.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Jul 2004 Posts: 2,998 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,998 | Years ago I put an aftermarket unit on a Chevy Bel Air I had. It had magnets that were fastened to the drive shaft, and a sensor that mounted near them. There was a servo unit that went under the hood, with a cable that hooked on to the carburetor linkage. I'm sure you'd have to look a bit to find such a unit today, but I'm sure there's one out there somewhere. It can be done. | | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | that dakota looks promising thanks | | |
