0 members (),
113
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62812 07/09/2006 9:50 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | will any of the manifolds interchange on the older 250 292s? from what I have seen every thing does not line up just right. | | |
#62813 07/10/2006 1:32 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | There shouldn't be any problems swapping 194/230/250/292 manifolds. The exception is replacing a Integral head with and earlier head. Can you be a little specific as to what is not lining up?
Larry
I don't own a vehicle that isn't old enough to drink. | | |
#62814 07/10/2006 4:28 AM | Joined: Oct 2005 Posts: 9 Junior Member | | Junior Member Joined: Oct 2005 Posts: 9 | 250 head on a 292 is simply a power thief wont breath as good course i smoke n i dont breath as good ether and i also lack power at times
1961 c65 flat dump 1973 c50 flat bed
#62815 07/10/2006 5:03 PM | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | Not sure why there should be any difference. The heads are interchangeable and have the same size valves etc. The manifolds will bolt from one to the other. I have mixed and matched them and haven't noticed a difference. | | |
#62816 07/10/2006 9:25 PM | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | most everything will interchange on these engines.
different between a 292 and 250 in the head is nothing. the only change was the 194 had a smaller cumbustion chamber, so it would up compression if used on a bigger doisplacement engine. other wise...the manifolds are exactley the same. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
#62817 07/11/2006 6:18 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Samwise has it right, the heads are all exactly identical for 230, 250, 292 engines. Just don't get one with integral manifolds, they are severly restricted on breathing. The 194 heads will bolt on but are higher compression and with smaller valves, not recommended for any performance increase. All manifolds will bolt up exactly, there is no difference in any of the 4 engine displacements. | | |
#62818 07/11/2006 11:19 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#62819 07/11/2006 2:58 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | another queerie.........
please explain exactly what makes an Integral head?
I'm only familiar w/ later swappable heads.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#62820 07/11/2006 5:02 PM | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | The integral head has the intake cast into the head, its all one piece. The intake runners are small and not well designed. The exhaust manifold comes off I think??? not 100% sure of that, but it to is a piece of smog crap. Its a very poor design for any kind of performance use. There is no headers or manifolds that work with this head. I threw mine away, never even looked at it!
The early heads with smog tubes are just the same as those with out. They simply drilled holes in the outer part of the exhaust port so the could inject fresh air in to the exhaust flow. The fresh air would help burn out some of the emissions. You can plug them very easy.
All of the other heads are so close in CC's except the 194, that they can be swapped with no problem. Intakes are all the same design as well as the exhaust manifolds. The later 292's might of had a different flange at the pipe outlet, but port design was the same.
The real difference in 230/250 and the 292 is the bore, stroke, block height, and camshaft. All the other parts will interchange. The cams will interchange as well if you use a electric fuel pump. Joe | | |
#62821 07/13/2006 6:44 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | The problem is that I have aqired a good manifold set from a "supposedly 292" for free to replace the broken one on my Brothers 292. But the center ports and bolts on the replacement manifold do not line up with cylender head when the outer bolts are installed
(so that was why I thought mabe it was a 250 part) | | |
#62822 07/13/2006 3:37 PM | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | It should go right on weather its a 292 or 250. Due to heat stress and age, the holes might not line up. If they are close, open up the tight ones a bit. Joe | | |
#62823 07/14/2006 12:48 AM | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | perhaps post a pic of the manifold if possible?
its the ports are square, its a 292/250. if they're round, 235/261.
or, atleast thats what i think i know...heh. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
#62824 07/16/2006 7:49 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I will try to get a photo
its for sure not 235 its the orgnl engine out of a mid 70s chevy Van | | |
