| | | Forums66 Topics128,164 Posts1,057,076 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 14 New Guy | | New Guy Joined: Jan 2010 Posts: 14 | I'm still in limbo trying to decide what motor/trans combo to use in my 53 GMC 1/2 ton. I've noticed in some restorations they had to modify the firewall and some even had to add a "hump" inside the cab to fit everything. I'd like to use a v8 or v6 motor and automatic trans and if possible and keep the orginal type radiator and not modify the firewall, is this a pipe dream?
Thank guys! Robin | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | No it's not a pipe dream. Don't cut the firewall unless you have exhausted every other possibility. Check out the gallery for other trucks and you will find lots that accomplish what you want to do. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | If I can stuff a 425/400 Cadillac combo in my truck w/out modifying it I'm sure any SBC or ever BBC will fit w/out cutting the firewall. You may have to move the radiator forward but other then that you shouldn't need to modify anything else other then possibly the steering if you keep the stock steering set up...joe | | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | I have a 327 & M21 in my '49. It fits with out modifying the firewall or moving the radiator.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Jan 2010 Posts: 14 New Guy | | New Guy Joined: Jan 2010 Posts: 14 | Thanks guys that's such a relief! I need a new radiator and wanted to use one i found that is a replica of the original and has the automatic tranmission conntections built in as well, that way it will bolt right in and it will look orginal. I also plan on adding power stering so moving the steering around was going to have to happen anyway. I'm wanting to add the mustang 2 front end for the IFS so i had enough work to do. When it's done it will be sweet, i wish i could wiggle my nose like Samantha on "Bewitched"(showing my age) and have it all done  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Trucks with 4 speed have a high hump cover over the trans. This might help if nessesary. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I put a small block in a 48 4400 without moving the trans forward. All I had to do is "clearance" an area around the large cap HEI dist. If I would have gone points or Mallory, wouldn't have had to, Scott | | | | | Joined: Jan 2010 Posts: 14 New Guy | | New Guy Joined: Jan 2010 Posts: 14 | Thanks Wrenchblender, hopefully going with an auto trans will keep me out of trouble  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I put a small block in my panel using the motor mount kit that does not utilize a crossmember. Using the measurements that came with the mounts it bolts in beautifull and I was able to have room for the automatic column shift linkage to get between the valve cover and firewall. I am also using the big distributor and I can still get my finger in behind it so I know I can get the dizzy out if I ever have to. Another point it that rather than cut the firewall I would have gone to the small distributor and and external coil to avoid cutting the firewall. Oh, and yes, I used a power steering box outside the frame. When doing this just be sure to measure your double "D" shaft or what ever steering shaft you use.... measure twice, cut once. Hope this adds to what the others have said and helps you out. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I used an sbc and the HEI and moved the radiator forward about 1.25". Moving the rad forward, if needed, is much easier than cutting the firewall.
~Jim
| | | | | Joined: Jan 2010 Posts: 14 New Guy | | New Guy Joined: Jan 2010 Posts: 14 | Thanks again guys...i love this forum. I know enough to get me in trouble but with a little help I just may get though this and have "James" back on the road again  | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Usually anything that had an inline 6 will take a small block without modifying the firewall. The 6 is 6 cylinders long, the V8 is 4 cylinders long, and the V6 is 3 cylinders long. Where you mount the engine will dictate if bottom of the firewall or floorpan work is necessary.
Evan
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I also installed an SBC with an HEI.There's even room for the fan as well. I didn't move the rad either The only trimming I've done was to the flange on the firewall directly above the trans bell housing. This was to allow me to get my pinion angles correct. The only other problem I encountered was the trans dipstick, an easy fix with a flexible dipstick.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I thing to remember is, it is best to position the engine as far back as possible.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | jock, your right on the money. Why didn't you tell me about the dip stick earlier??  I bought one but found out recently I would need a flex OR bend the one I have. I think I'll return it and and use the money toward a flex. No use getting frustrated over something if we don't have to. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sorry Alvin!  I actually got my trans dipstick in but it's just touching the firewall. There's just not enough room to allow for the engine 'torquing' I had always planned for a flexi one for some eye candy anyway! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | The only problem I had was the shift linkage. The shop that installed my engine mounted it without moving the rad. When the steering column was installed the linkage wouldn't clear the valve cover so I had to go with the floor shifter.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | All rods should have floor shifters.
~Jim
