Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (walter74, TUTS 59, 1955 1 Series, 51sub, farmallb, 1 invisible), 40 guests, and 1 robot.
Topics128,005
Posts1,055,256
Members48,418
#621653 02/20/2010 1:29 AM
My 51' GMC was assembled with a lot of star washers was this orginal? jimmy
jimmy1 #623790 02/26/2010 4:10 PM
like where ?
Door hinges, and latch assm had them.
They are original and are referenced in the Master Part Catalogs.
,,, another place to check for them is at Ace Hardware. My home town store never ceases to amaze me at what they pull out.... and a week ago the owner told me he would have LOTS more nuts/bolts/springs ect ect in about a month. He told me "you'd be surprised how many folks are sent here to Ace by the parts stores!!
Also, if your blessed with a CArson Nut and Bolt place your even better off. There is one in Spartanburg and I go there fairly often..... if Ace doesn't have it smile
Harbor Freight sells a box of them for $6-7 dollars should be all you need. They are really designed as one use washers and should not be re-used if you are concerned about something coming loose.
Apprentice
Apprentice
If you cant find any I'd just set the washer on a flat surface strike it once with a baby sledge hammer or sheet metal hammer so it's flat then twist each point with a small pair of needle nose at about 45 degree angles all the same way, time consuming but effective. Or check Tractor Supply Company as well.
If the frame is Good then everything else can be fixed.
1930 Chevy 1/2 ton (Sold her)
1948 Ford f-5 (Shot her)
1951 Willys-Overland Wagon (Lost her)
1959 Chevy Apache Fleetside (Left her)
1956 Oldsmobile Super 88 (Drive her)
Ace even has the conical shaped stare washers though a little pricy.
