1 members (baldeagle),
40
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | My 51' GMC was assembled with a lot of star washers was this orginal? jimmy | | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | like where ? Door hinges, and latch assm had them. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are original and are referenced in the Master Part Catalogs. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ,,, another place to check for them is at Ace Hardware. My home town store never ceases to amaze me at what they pull out.... and a week ago the owner told me he would have LOTS more nuts/bolts/springs ect ect in about a month. He told me "you'd be surprised how many folks are sent here to Ace by the parts stores!! Also, if your blessed with a CArson Nut and Bolt place your even better off. There is one in Spartanburg and I go there fairly often..... if Ace doesn't have it  | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Harbor Freight sells a box of them for $6-7 dollars should be all you need. They are really designed as one use washers and should not be re-used if you are concerned about something coming loose. | | | | | Joined: Jan 2010 Posts: 22 Apprentice | | Apprentice Joined: Jan 2010 Posts: 22 | If you cant find any I'd just set the washer on a flat surface strike it once with a baby sledge hammer or sheet metal hammer so it's flat then twist each point with a small pair of needle nose at about 45 degree angles all the same way, time consuming but effective. Or check Tractor Supply Company as well.
If the frame is Good then everything else can be fixed. 1930 Chevy 1/2 ton (Sold her) 1948 Ford f-5 (Shot her) 1951 Willys-Overland Wagon (Lost her) 1959 Chevy Apache Fleetside (Left her) 1956 Oldsmobile Super 88 (Drive her)
| | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Ace even has the conical shaped stare washers though a little pricy. | | |
