0 members (),
49
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Had to remove the seat on my 65 yesterday to pull the tank and found both build sheets under the springs. Carefully removed them and ran them through a scanner and put them back. Should I leave them in place or remove them for safe storage?
1955 Chevy 3100
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I would bag then put them back using a one-gallon zip-lock. They will continue to deteriorate at a slower rate but still be contained in the same place. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... make two set of the scanned papers and put one of the new ones back with the original.... for posterity! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It is common practice to laminate build sheets for future safe keeping. Most office supply stores have a laminate service.
Drew
