8 members (Ponchogl, Bill Hanlon, MickeyP, Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Charles in CA, 48ed56pam),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | After chiseling out the 58 year old rubber from the wing vents and outside door wiper I am not looking forward to removing the windshield and back window rubber. It is hard as a rock. Laughs at my attempts to cut into it. Anyone have any tricks to deal with this or am I back to hammer and chisel? Chuck | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | When I did my vents, after doing one, I decided to try my dremel tool. I used a bit and cut it right down the middle of the channel. That did it! I was able to break that rubber in the middle and pull it out it fairly good sized chunks. I hope that helps ya out!
58' 3200 235 3-speed/OD
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...On the windshield there is a "lip" that goes over the pinch weld to the inside. So, just sit down in the truck, take a cut sharp knife and cut the "lip" off. Once that is done just push the windshield out because when you cut the lip thats holding it in there the only thing holding it would be some old weatherstrip adhesive applied long ago around the outside of gasket. (what was put between gasket and body) | | |
