| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61774 06/15/2006 12:58 PM | Joined: Jun 2006 Posts: 18 Apprentice | | Apprentice Joined: Jun 2006 Posts: 18 | I have a 1950 1/2 ton Chevrolet pickup with stock drivetrain. I am pulling the locked up 216.5 and have access to a good 250. I would really like to keep my stock transmission and rearend for now. Can I make a 250 work? What mods would I need to do? Thanks for the help. | | |
#61775 06/15/2006 2:59 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | You'll need to find the bell housing for a '63 + truck with the Muncie 4 speed tranny as they used that up to'68 that I know of...
Engine Mounts will need to be fabricated too .
it's far easier to hunt the Task Force boards and find a good 235 takeout from a hot rodder , these are alwaay very cheap , even fully rebuilt 235's don't go over $500.00.....
Good used ones only cost $150.00 + / - , fan to clutch , check the older ads as these engines will still be sitting there in three years if not scrapped.
Good luck hunting ! .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#61776 06/16/2006 12:11 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Brian,
The response you received from vwnate1 is correct. At a minimum, you will need to fabricate motor mounts etc.
The combination you're asking about is a good set-up. I had an early 70's 250, stock 4-speed, and torque tube rear-end in a 52 that I recently sold.
It would run circles around my 216 and "early" 235. I also liked it because it came with hardened valve seats (for unleaded gas) and a stock HEI ignition system.
I'd weigh your abilities to fabricate the mounts etc. and the cost of the engine your looking at to what you find looking for a 235.
I don't imagine you'll be that far apart $$ wise, as most people that have the 250's are generally looking to practically give them away as well.
The 235 is probably gonna require that you either fabricate new motor mounts or drill out the holes to front mount it. Then you still have to work with clearance issues on the water pump.
Either way, it can be done, and it shouldn't be that difficult. | | |
#61777 06/16/2006 2:56 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think the bellhousing search is a little wider than '63+. The bellhousing from a '55 to '68 V-8 powered truck will work.
I'll also add that you will either want the bellhousing crossmember from a '54 or '55 1st pickup or you will need to make adapters to mount the bellhousing on your existing bellhousing.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#61778 06/16/2006 4:25 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by OldSub: I'll also add that you will either want the bellhousing crossmember from a '54 or '55 1st pickup or you will need to make adapters to mount the bellhousing on your existing bellhousing. That ain't so hard to do, Scott | | |
#61779 06/16/2006 5:52 AM | Joined: Apr 2006 Posts: 23 Member | | Member Joined: Apr 2006 Posts: 23 | Brian come out & look through my junk, I mean treasures I think I have a bell housing you need. Neal | | |
#61780 06/16/2006 8:57 PM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | OLDSUB IS CORRECT, REGARDING THE FRONT MOUNT THERE ARE TWO TREADED HOLES IN THE FRONT OF THE BLOCK ON EACH SIDE OF THE CRANK SHAFT PULLEY. YOU CAN MAKE A HORSESHOE MOTOR MOUNT BRACKET SO YOU CAN MOUNT THE MOTOR LIKE A STOCK FRONT MOUNT. USE A 54 TRUCK BELL HOUSING X MEMBER AND A 1955-59 V8 BELL HOUSING. YOU CAN USE ONE OF THE THREADED HOLES ON THE DRIVERS SIDE OF THE BLOCK FOR YOUR GAS LINKAGE SWIVEL TO HOOK IT UP LIKE STOCK. RUNNING A 250 WILL BE WORTH THE XTRA WORK. | | |
