2 members (55shaker, 1 invisible), 55 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#609212 01/11/2010 10:03 PM
I have searched , but I don't see any posts regarding exhaust systems for my 37 original restoration. I'm looking for the best exhaust system that is available that represents an original style system. I am not opposed to using a stainless system if it' in the original design. Any opinions or experiences- good or bad? Thanks
I would like this information also.
1937 Chevy 1/2-Ton
well, I may as well put in my .02 worth.
First I would take my truck to a local reputable shop that specializes in exhaust system. Their stuff should be better and even less expensive than any system you can buy from any vendor.
They usually will have two grades of pipe.....some only carry one
Show them the route of the original pipe and let them do the entire job. It will look good, not be expensive as trying to buyh the stuff and do it yourself.... unless you have a pipe bender and buy the straight pipe lengths. I'd use 2" pipe.
Good information, Alvin. I agree.
Thanks I think that's where I am headed, but wanted to see what others had done.
What about Waldron's Antique Exhaust?
www.waldronexhaust.com
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I used a Walker #21028 on my 38. I think it is the same muffler for all the 6 cyl's from the 30's to the 50's. Thay also have the correct band type hanger, #35609. Stan S.
Thanks !
I went to the local muffler shop and talked to the owner. I told him what I had and he told me he had all the old recepies for bending the pipes clear back to the 1920's.Sure enough he let me back in the shop and let me watch him bend the pipe. The bending specs. were on recepie size cards. He pulled out a new piece of pipe and bent it up. Down pipe and tail pipe were only about 100 bucks. I purchased the muffler from Jim Carter. Took it all home and it bolted right up. A good shop should be able to make your pipes.
