2 members (dt235sd, ndkid275),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60910 05/25/2006 11:05 PM | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Hiyas. My dad has a '57 235 inline six in his '53 truck. After the recent fiasco with the rainwater in the engine and thus the oil because of an unsecure valve cover and other things... , dad bought a valve cover gasket for it. You can read about that adventure here, if you like: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011457 The gasket is of the cork material. Now, I am just checking in here about the installion. Put cork gasket down on top of the head, put valve cover on top, line up valve cover and gasket with each other and the bolt holes on the head, and then snug it down with the bolts? Should we use any sealer stuff? Maybe just a dab here and there to stick the gasket onto the valve cover? Thought I'd ask... I never know what you folks might know. -W | | |
#60911 05/25/2006 11:10 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Woogeroo, I would use a little gasket cement and stick the gasket to the valve cover. It's kinda difficult to keep it lined up on the head.
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#60912 05/26/2006 12:12 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I put studs on my head, that eliminated most of the alignment problems. I also used Permatex high-tack (the yellow kind that cimes in a tube) to seal it completly.
Bill Burmeister | | |
#60913 05/26/2006 1:19 AM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I always covered 1 face of the gasket completely and stuck it to the cover. let it set up a bit and install. Dont overtighten the bolts you will warp the cover | | |
#60914 05/26/2006 2:17 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | then after you drive it for a week or so re-tighten them a little. The cork gaskets will "settle" down, or compress a little and thats when the leaking starts!! | | |
#60915 05/26/2006 10:53 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I glue them to the valve cover on most other engine models but a 235 the gasket has to clear the head bolts & therm housing. It may be hard to get on. If the cover is in good condition & straight & you have a good fresh gasket I put it on dry. It can be reused that way. Like chipmonk says retighten after a while but like gazim says don,t overdoit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#60916 05/26/2006 11:42 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I got some of those "T" shaped washers (@ car quest)to hold the cover down. I had to grind them a bit so they'd fit, but I figured this distributes the force of the 4 bolts a bit more evenly. | | |
#60917 05/27/2006 2:49 PM | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Thanks a bunch everyone... more responses than I thought I'd get with some good thinkin' in them. -W | | |
#60918 05/28/2006 2:14 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello woogeroo, i was thinking about how the water could get on the valve cover, gasket or not, but for the cowl vent drain. does that truck have a cowl vent? if it does , the drain hose must aim right at the valve cover. i noticed this on mine and i'm going to change the direction of the hose so the water from the drain won't hit the engine. hope this helps! good luck.
our garage is a non-profit organization
#60919 05/28/2006 3:23 AM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Yup, Put gorilla snot between the gasket and valve cover. Keep the side between the gasket and head clean. It has worked very well on my 62 235 in my 50 ad as well as the valve covers on my daughter's Mustang.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#60920 05/28/2006 2:55 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | clean the surface on the head. i use a "new" wood chisel as a scrapper. be sure the cover is flat. the bolt holes are usually pulled down into "humps'. tap them back and clean the cover real good also. a little cement is ok. the stud idea is great. we used thread to tie the gasket to the cover and a lot of carefull positioning. pain in the neck.
"It ain't a truck if you can't hose out the cab."
