5 members (WICruiser, Hotrod Lincoln, moparguy, Barney1951, Peggy M), 54 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#60876 05/25/2006 6:15 AM
I am ready to start thinking about my putting my radiator back in the truck ('52 AD 3100). I really like the looks of the aluminum one but they are really pricey. Does anyone know of a good but reasonable place to find one? Any advantages / disadvantages on going with the aluminum?
#60877 05/25/2006 1:08 PM
Best price around I bought from Jegs
26x19 part # 055551174 for $169.99 inc frt.
turned out real well, I'm satisfied it cools extremely well.
#60878 05/26/2006 4:04 AM
Thanks for the information Gazim. I looked it up and isn't that a radiator for a v-8?
I guess that I should mention that I am looking for the original radiator for the 6 cylinder.
#60879 05/26/2006 12:40 PM
YUP it is for a 8, I didn't look but they usually have other sizes. sorry
#60880 05/26/2006 2:57 PM
Maybe the A.D. trucks are different, but the stock radiator in my I6 truck is the same as the one that came with the 283 and 327 of the same year.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#60881 05/26/2006 3:40 PM
The number of cylinders in the engine the radiator is advertised for doesn't matter-
What you should be looking at is the dimensions, number of rows, outlet hose locations and diameters, and mounting flange specs.
It would be great if there is an 'off the rack' aluminum radiator out there the bolts right into the radiator mounts, but since the flanges are brazed on at an angle on the stock one, I'd be a bit surprised if there were.
#60882 05/27/2006 1:27 PM
Well the one i purchased from speedway was 4 core, right top and left bottom hose locations when facing the radiator from the front. I had to fabricate mounting brackets myself but not very difficult when the radiator is lthe right size,
#60883 05/28/2006 4:07 PM
Griffin Radiator has one that looks original and bolts in like original and is aluminum. Or so they say, I am interested but want to see at least a picture of what I will be spending my money on. I called and asked if they could email a picture, they said all they had was the engineering drawing. I have yet to get it.
I will try again, but if they can't show me what I am buying before I hand over the money they don't need my business.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#60884 05/28/2006 4:31 PM
and it definitely won't be cheap or even economical from Griffin..... so check your checkbook first.
#60885 05/28/2006 8:00 PM
I know they are not cheap from Griffin, but I believe they are of excelent quality.
I want a very reliable and nicely put together truck. The cost is not my first concern.
---All pictures---
#60886 05/29/2006 5:07 PM
The aluminum radiators from Speedway are fine quality and as Gazim says, they come without the mounting flanges attached. So, you could get the radiator from them and mark where you want the flanges and then have either a radiator shop or a welding shop heli-arc them for you.
