2 members (tesa, Ponchogl),
50
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Happy new year all. Got some air tools for christmas so was changing the oil in my compressor (champion v-twin portable) and moving it from a somewhat warm basement to a cold non heated shop.The owners manual or company website doesn't give any oil recommendation, I got a iso 32 weight ,but it is a lot more runny than what was drained out.My thinking that it was going to a cold shop so I needed a thin oil.I think I should have got the 68 weight compressor oil now. Can anyone steer me to the better choice? Thanks Murray | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I run both of mine on 30 weight non-detergent from the local farm store. Runs fine on it. And alot cheaper, too.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I use synthetic oil in all my compressors. http://www.mobil.com/USA-English/Lubes/PDS/GLXXENINDMOMobil_Rarus_400.asp All of my compressors are outside of buildings and we have weather ranging from single digit to 110 degrees and a lot of periods of high humidity. Synthetic is a lot more tolerant to moisture than mineral oil. I have 3 or 4 Champions which I consider a premium compressor. I change the oil in all my compressors twice a year. I used to consider myself lucky to get 5 years out of a compressor. I switched to synthetic about 15 years ago and have not had a compressor to fail since. Mobil can be purchased from WW Grainger. | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | TP Tools Use this in mine. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I buy the Ingersol Rand compressor oil at the Tractor Supply store.Which reminds me, my compressor is due for an oil change. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Yes, synthetic is the way to go. This is what I use in mine.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | is it just me or does any one else find it weird that the oil is blue? What makes it like that? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | is it just me or does any one else find it weird that the oil is blue? What makes it like that? Pretty blue dye! Stuart | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Exchanged the 32 for the 68 compressor oil which is supposed to be the same viscosity as a 30 weight oil.then of course I found some 30 non detergent oil in the shed that I used to use for the clipperhead when shearing sheep,oh well there was't enough anyway. Thanks guys for the info | | |
