5 members (J Lucas, Gray_Ghost, msmall, 2 invisible), 93 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#606100 01/01/2010 3:50 PM
Happy new year all. Got some air tools for christmas so was changing the oil in my compressor (champion v-twin portable) and moving it from a somewhat warm basement to a cold non heated shop.The owners manual or company website doesn't give any oil recommendation, I got a iso 32 weight ,but it is a lot more runny than what was drained out.My thinking that it was going to a cold shop so I needed a thin oil.I think I should have got the 68 weight compressor oil now. Can anyone steer me to the better choice? Thanks Murray
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
I run both of mine on 30 weight non-detergent from the local farm store. Runs fine on it. And alot cheaper, too.
Bill Burmeister
I use synthetic oil in all my compressors. http://www.mobil.com/USA-English/Lubes/PDS/GLXXENINDMOMobil_Rarus_400.asp All of my compressors are outside of buildings and we have weather ranging from single digit to 110 degrees and a lot of periods of high humidity. Synthetic is a lot more tolerant to moisture than mineral oil. I have 3 or 4 Champions which I consider a premium compressor. I change the oil in all my compressors twice a year. I used to consider myself lucky to get 5 years out of a compressor. I switched to synthetic about 15 years ago and have not had a compressor to fail since. Mobil can be purchased from WW Grainger.
TP Tools
Use this in mine.
Mobil Rarus
I buy the Ingersol Rand compressor oil at the Tractor Supply store.Which reminds me, my compressor is due for an oil change.
Yes, synthetic is the way to go.
This is what I use in mine.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
is it just me or does any one else find it weird that the oil is blue? What makes it like that?
Pretty blue dye!
Stuart
Exchanged the 32 for the 68 compressor oil which is supposed to be the same viscosity as a 30 weight oil.then of course I found some 30 non detergent oil in the shed that I used to use for the clipperhead when shearing sheep,oh well there was't enough anyway. Thanks guys for the info
Moderated by  MNSmith
