7 members (Rusty Rod, TUTS 59, 55shaker, RLB, WICruiser, Gdads51, Jay R),
102
Mod | | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 40 | I want to replace my rear door lock. It has a cover and is held in place with a clip at the edge of the door. Will a door lock from earlier then my 54 work? Thanks for all help. Karl | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The rear door locks are all the same from 1947/55. My guess is that other style locks from the front doors will work if you use the connecting rod from the rear door lock.
Why are you replacing the lock? A locksmith can make a new key for it to match the front door locks. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I recently ran into the best vintage automotive locksmith ever. He had all my 4 locks good as new in an hour. (They were BAD) He had boxes and boxes of old locks and all the blank keys you could ever need for any GM till the newest style began. (About 1400 different keys, all numbered) Best of all, he didn't charge for advice and info on anything.
To answer your question, I don't think locks changed much from year to year, series to series, just the housings. | | | | | Joined: Dec 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 40 | Thanks for your help. At the present, I have different keys for each of the front doors and wanted to be able to lock the rear also. I live in a small town, I will try to find a locksmith that can help. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks for your help. At the present, I have different keys for each of the front doors and wanted to be able to lock the rear also. I live in a small town, I will try to find a locksmith that can help. Take all of the locks to the locksmith including the glove box. He can clean them up and re-key them to a new code or if you have a key that you want to keep, he can key them to that one too. Years ago, I took it down to an old locksmith and he showed me how to do it myself, gave me the parts and didn't charge me a dime. Maybe this guy will help you out too. | | | | | Joined: Dec 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 40 | Thanks, I had not thought about the glove box lock. This will be the way to go. Now I have to find a locksmith less then 100 miles away. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I took my locks to a locksmith and he seemed to enjoy working on something that old. He made me multiple keys for a very reasonable charge. | | | | | Joined: Dec 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 40 | Hey, I found a locksmith close by that can help me. Now all I have to do is put on 6 layers of clothing to stay warm while I pull all the locks for him.
Thanks all for the responses. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Nice that you found one Karl. I have a locksmith here in town (been there for years). While the "going rate" for working on an old lock appears to be around 20-25 bucks this locksmith fixed and keyed all mine for $7.50 each.... and as someone said, he seemed to enjoy working on the ones he remembered quite well. Good luck. | | |
