4 members (rick46ia, Hotrod Lincoln, Otto Skorzeny, 2-Ton), 101 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
#599498 12/09/2009 12:15 AM
Your should be able to lock the door from inside are you not?
joes1952 #599501 12/09/2009 12:36 AM
only if it is closed. when open it won't lock
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Pushing the inside handle the opposite way to when you open it, should prevent anyone from opening it from the outside. This cannot be opened with a key.
1951 1 Ton Completed
truckernix #599595 12/09/2009 4:44 AM
joes1952... if your having trouble you "Might" have the wrong door control on the wrong side. I run into this because of a previous owner situation and had questioned some things due to the door handles working "sort of backwards" and found that I needed the door control for the correct side.
May not even be close but just trying to help!
