0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59937 05/02/2006 8:05 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | A friend wants me to help him get his '50 chevy truck operable. :rolleyes: How do you replace the seal on the outside of the "bell" on the torque tube?As the truck was delivered,the four bolt flange was unbolted and the "seal" was shredded. I've not seen what the seal looks like intact-can it be replaced without moving the rear end back and seperating the u-joint or pulling the engine and tranny? :confused: Speed | | |
#59938 05/02/2006 12:55 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Speed,
You will have to remove the u-joint and yoke from the driveshaft side. With the u-joint and rear yoke off, the u-joint housing (bell) can be removed. The gasket/seal kit has:
1. the cork seal for between the bell and the retainer; and, 2. the rubber seal for the rear "neck: of the bell to the driveshaft; and, 3. 4 paper gaskets for between the retainer and the rear of the transmission (a procedure for choosing the correct number of gaskets is in the shop manual - it is a good procedure).
There is no need to remove the transmission and torque-tube. After removing the u-joint, the torque-tube will rotate downwards (and upwards).
Tim | | |
#59939 05/03/2006 6:26 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The set I bought years back had a bevelled rubber ring for use between the housing and the retaining collar. As mentioned by tclederman, there are four paper gaskets which help to determine how much spacing is needed between the collar and the transmission. It is indeed very well described in the shop manual. The advantage of the individual paper gaskets is that if you have leakage in the collar area sometime later, you can loosen the four bolts and rip out one of the gaskets, making the joint tighter. They might seem thin but they are effective and there is a difference in movement of the housing when using one or four. | | |
#59940 07/06/2006 8:23 PM | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Where can you purchase these seal kits. Thanks. | | |
#59941 07/06/2006 10:36 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Jim Carter in Kansas City has them. | | |
#59942 07/07/2006 3:55 AM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I just got a 3.55 gear set from Patrick's and included in it is a Fel Pro "Universal Joint Set" gasket set that includes 1-CR5158 Universal Joint packing, 4-729 Universal Ball collars, 1-CR18280 Universal Joint Ball Collar, and 4-18290 Universal Joint Retainer Shim. Part Number for entire kit is ES72843 Uses are Chevrolet 6 Engine 1935-54 and Chevrolet Truck 6 Engine 1935-56 See Master catalog for complete model data. Anyway, FelPro gaskets pretty much available at any parts store. | | |
#59943 07/08/2006 4:57 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Your really talking about the bell housing seal. Not the torgue tube seal. So the question is. Do you have to remove the drive shaft to remove the old torque tube bushing and seal when you want to install an okie bushing?
Glenn, | | |
#59944 07/08/2006 12:59 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Your really talking about the bell housing seal. Not the torgue tube seal."
GMC52, are you are referring to speed? It looks like he might be referring to the torque-tube u-joint housing (bell). Of course, we could be wrong, and it is always good to clarify terminology.
"How do you replace the seal on the outside of the "bell" on the torque tube?As the truck was delivered,the four bolt flange was unbolted and the "seal" was shredded." | | |
#59945 07/08/2006 2:20 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | TC, I did not write that very clear. Yes, I am referring to Speed. Now my seperate question is. How do you remove the old seal and bushing inside the torque tube when you want to replace it? Do you need to move the shaft aft to get the special puller in the tube? Hope I'm clear.
Glenn, | | |
#59946 07/08/2006 2:41 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Glenn,
That's a good question and I would also like to hear a descriptive answer for it. In fact, it would be real nice to "see" an answer to your question (a photo tutorial).
My understanding is that there is some kind of puller-tool to remove the existing seal. The torque-tube can be rotated downward; therefore, this repair can be done with the rear end in place. Also, there is an inner bearing (and seal ?) behind the outer seal and the inner bearing gets pushed back on the enclosed driveshaft by the repair (Oakie) bushing.
If you undertake this repair/replacement, maybe you could post your experiences here?
Good luck, Tim | | |
#59947 07/08/2006 3:25 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The reprint of the Chevrolet rear axle overhaul booklet covers all the above and shows each step pictorally. I thought the "torque tube seal" is the felt ring inside the ball nut. When using an okie repair bushing you just slide it over the shaft and pound it in but to replace the original bushings and propeller shaft seal? the rear end must be disassembled and the shaft/bearings removed. Then the bushings/seal can be removed with a puller. (shown in the book) http://www.classicparts.com/prodinfo.asp?number=05-711
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#59949 07/08/2006 5:02 PM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | As I understand it, there is a puller to pull front bushing in driveshaft. Then the Okie bushing drives the old rear bushing out of the way and has it's own new seal. I will scan the "Patrick's 3.55 gear installation instructions" In it, the driveshaft is removed from the outer tube and he gives instructions to use a 6' length of 1" pipe with a cap to drive out the old bushings and seal and installation instructions for installing new original style bushings and seal. I will e-mail those instructions to Tim as he has been real good to post stuff like that for me. My ISP does not provide ftp space. | | |
#59950 07/12/2006 4:05 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | All good info. But, I'm still alittle confused. I know that there is a special tool to pull the bushing. I have looked at the end of the torque tube and drive shaft and am here to tell you that there is so lttle clearance between the shaft and the tube that I'm surprised that the tranny yoke will slide on. So the question really is.Will that special tool fit over the shaft and between the shaft and torque tube? Or do you have to move the shaft back? Glenn, | | |
#59951 07/14/2006 5:28 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I took the old bushing out by drilling and tapping two small holes in the end of the old bushing. I threaded in two machine screws and used a slide hammer to pull the old bushing out. When I put the okie assembly in I used and old u-joint yoke and once over the splines hammered the assembly in using the yoke as a drift of sorts. | | |
#59952 07/14/2006 9:11 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | There is a special torque tube bushing remover but last time I checked, none of the vendors had them and wouldn't for a few months. Some of the bushing are held in with a retainer bolt on the outside of the torque tube. If you have one of those, the job to remove the old bushing may be easier. Once the old bushing is out, the new Okie repair unit is driven in and drives the old bushing back down the tube. You need to dress the splines of your shaft to ensure that the new seal on the new bushing unit is not torn during installation. I have two of these old Okie bushing kits s with instructions so hopefully I'll be successful when I do mine after the engine goes back in. I'll be doing this soon myself and plan on doing a photo and knuckle breaking narrative when I do it. Probably too late for you guys as I won't be doing it until next month. I'll be watching your progress though. | | |
#59953 07/15/2006 5:39 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Thx Geezer. Every bit of info really helps with the big picture.
Glenn, | | |
