4 members (Otto Skorzeny, Phak1, Gdads51, Ponchogl), 131 guests, and 3 robots.
Topics128,272
Posts1,058,316
Members48,485
#59708 04/26/2006 6:25 PM
I plan on putting a T5 into my '54 3/4 ton (open drive line). Is there any disadvantage in replacing the two piece drive shaft& carrier bearing assembly with a single drive shaft? Why did GM use a 2 piece drive shaft in the first place?
Thanks in advance.
#59709 04/26/2006 7:20 PM
I do not see why you could not replace your 2 pc with a one piece shaft if the dimensions are right. In my opinion the primary reason for using the closed center front shaft was to be able to have a single transmission that could be used in either the 3100 or the 3600 series trucks. Certainly the length of the shaft must be considered but assuming it is 3" x .083 or larger and not over 55" weld/weld you should be OK. Properly built it doesn't require balancing either. If it needs to be longer than that then YES, a carrier bearing and rear shaft are necessary.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#59710 04/26/2006 7:20 PM
This would be a good question for a driveshaft shop. Depending on shaft diameters and material used there are maximum allowable lengths. If the shaft is too long it will begin to whip, kinda like a jump rope. If it is too severe, it will pull out of the trans, a failure I wouldn't want to experience. An interesting side note, the Lincoln MK8 was speed limited for this very problem. John
#59711 04/27/2006 3:03 AM
On a single piece shaft, the yoke slips in and out of the tailshaft housing. On the two piece, the shaft has a slip yoke built into the drive shaft because the trans has a solid yoke. If you're going to the T-5 that has an open tailshaft housing, you'll need a one piece drive shaft,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#59712 04/27/2006 10:00 PM
Thanks for the replys
#59713 04/28/2006 5:43 AM
Junior Member
Junior Member
Remember the old 62-64 Impalas that came with a 425HP 409 CID? They had 2 piece drive shafts. You can get the job done with a two piece. Try a poly center support bearing from Inland Empire Driveline http://www.iedls.com/home.html I run 400 hp through a 2 piece with no problems...
1962 Pontiac Laurentian w/ factory 261 (Canada)
