| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59708 04/26/2006 6:25 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I plan on putting a T5 into my '54 3/4 ton (open drive line). Is there any disadvantage in replacing the two piece drive shaft& carrier bearing assembly with a single drive shaft? Why did GM use a 2 piece drive shaft in the first place?
Thanks in advance. | | |
#59709 04/26/2006 7:20 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I do not see why you could not replace your 2 pc with a one piece shaft if the dimensions are right. In my opinion the primary reason for using the closed center front shaft was to be able to have a single transmission that could be used in either the 3100 or the 3600 series trucks. Certainly the length of the shaft must be considered but assuming it is 3" x .083 or larger and not over 55" weld/weld you should be OK. Properly built it doesn't require balancing either. If it needs to be longer than that then YES, a carrier bearing and rear shaft are necessary. | | |
#59710 04/26/2006 7:20 PM | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | This would be a good question for a driveshaft shop. Depending on shaft diameters and material used there are maximum allowable lengths. If the shaft is too long it will begin to whip, kinda like a jump rope. If it is too severe, it will pull out of the trans, a failure I wouldn't want to experience. An interesting side note, the Lincoln MK8 was speed limited for this very problem. John | | |
#59711 04/27/2006 3:03 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | On a single piece shaft, the yoke slips in and out of the tailshaft housing. On the two piece, the shaft has a slip yoke built into the drive shaft because the trans has a solid yoke. If you're going to the T-5 that has an open tailshaft housing, you'll need a one piece drive shaft, Scott | | |
#59712 04/27/2006 10:00 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | | | |
#59713 04/28/2006 5:43 AM | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | Remember the old 62-64 Impalas that came with a 425HP 409 CID? They had 2 piece drive shafts. You can get the job done with a two piece. Try a poly center support bearing from Inland Empire Driveline http://www.iedls.com/home.html I run 400 hp through a 2 piece with no problems...
1962 Pontiac Laurentian w/ factory 261 (Canada)
