6 members (Greg_H, NorCal52Suburban, Hush, Cosmo, LAROKE, 1 invisible), 70 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
#59580 04/24/2006 3:53 AM
Junior Member
Junior Member
I have a 1966 Catalina with a 389ci engine. The motor was completly rebuilt and has about 3500 miles since rebuild. When you have the car in park and rev the engine up to 3000rpm or so and then let off the gas, the engine knocks. Also has a mild knock at idle. No knock when engine speed is increased. Good oil pressure. I am guessing wrist pin. Any ideas? I would like to invite everyone to visit my new wbesite, www.ClassicFastCars.com. Lots of great Articles, Restoration Tips, Technical Information, Production Data, Photos, Forums, Links and adding more content daily.Feel free to leave any questions, comments, or suggestions you might have.
#59581 04/24/2006 10:12 PM
Riding in the Passing Lane
Check the harmonic balancer. Those old pont. were nortorious for the rubber comeing loose or the hub loose on the crankshaft. If not check the tork converter bolts.
1972 Chevy c10 Cheyenne Super
#59582 04/25/2006 1:10 AM
Excessive crankshaft endplay will make that noise when the engine is unloaded like that,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#59583 04/25/2006 8:49 PM
That's the chipmunks knocking on the valve covers. You forgot to feed them.
