7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf), 74 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#59454 04/21/2006 2:27 AM
Junior Member
Junior Member
If I want to keep the original motor,tranny and driveshaft but put another rearend to be able to go regular speeds,what type of rearend would be best to install on a '53 chevy if its OKAY??what gear ratio and all.
If ain't broke Break it and fix it.
#59455 04/21/2006 3:11 AM
If its a half ton you will need another tranny and driveshaft.
Try a search on rear end or rearend ratio, you will enough info to keep yourself busy for weeks.
#59456 04/21/2006 4:03 AM
To keep the original tranny and torque tube your only option is to change the ring & pinion on the 3100 series. There is a 3:55 gear set available from Patrick's for about $700 with bearings & seals.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#59457 04/21/2006 4:08 AM
If you want to keep everything stock, assuming 1/2 ton torque tube, for a 53, your only option is the replacement ring and pinion gears. For this set up, your only option is 3.55 gearing in your original rearend. If 3/4 ton, option are different. If 1/2 ton 4 speed, you can keep tranny, but go to open driveline with different rearend with some modifications and fabrication. If three speed, 1/2 ton, you will need new tranny if you want to switch rear ends, I guess what I am saying is, what do you have?
Steve O
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
#59458 04/21/2006 12:58 PM
Junior Member
Junior Member
Ite a 235 with a 4-speed.
#59459 04/21/2006 2:58 PM
if you decide to change out that old out of date rear end...
It's about the same price to buy a modern rear-end w/ MUCH better brakes. But along w/ that you will need a new drive shaft. Depending on your choice of rear-ends, the E-brake situation will just be a very simple change over.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000876;p=1#000004
Jim & Caroline
#59460 04/21/2006 3:00 PM
http://www.chevytrucks.org/tech/rear_ends.htm
Jim & Caroline
#59461 04/23/2006 4:14 PM
If you are thinking about going with a new rear axel, drive shaft and five speed tranny, there is a 12 bolt posi with 3.42 gears in the swapmeet, with 6 lug bolt pattern- so you could use your stock rims, and it appears to be the same width as the original axel in my '51.
#59462 04/24/2006 4:13 PM
It seems to me that Jeg's and/or Summit sells the different ratio rear end gears for the older rear ends. I think they are a lot cheaper to.
