| | | Forums66 Topics128,266 Posts1,058,369 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59454 04/21/2006 2:27 AM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | If I want to keep the original motor,tranny and driveshaft but put another rearend to be able to go regular speeds,what type of rearend would be best to install on a '53 chevy if its OKAY??what gear ratio and all.
If ain't broke Break it and fix it.
#59455 04/21/2006 3:11 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | If its a half ton you will need another tranny and driveshaft.
Try a search on rear end or rearend ratio, you will enough info to keep yourself busy for weeks. | | |
#59456 04/21/2006 4:03 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | To keep the original tranny and torque tube your only option is to change the ring & pinion on the 3100 series. There is a 3:55 gear set available from Patrick's for about $700 with bearings & seals. | | |
#59457 04/21/2006 4:08 AM | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | If you want to keep everything stock, assuming 1/2 ton torque tube, for a 53, your only option is the replacement ring and pinion gears. For this set up, your only option is 3.55 gearing in your original rearend. If 3/4 ton, option are different. If 1/2 ton 4 speed, you can keep tranny, but go to open driveline with different rearend with some modifications and fabrication. If three speed, 1/2 ton, you will need new tranny if you want to switch rear ends, I guess what I am saying is, what do you have? Steve O | | |
#59458 04/21/2006 12:58 PM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | Ite a 235 with a 4-speed.
#59459 04/21/2006 2:58 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you decide to change out that old out of date rear end... It's about the same price to buy a modern rear-end w/ MUCH better brakes. But along w/ that you will need a new drive shaft. Depending on your choice of rear-ends, the E-brake situation will just be a very simple change over.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000876;p=1#000004
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#59460 04/21/2006 3:00 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000876;p=1#000004 http://www.chevytrucks.org/tech/rear_ends.htm
#59461 04/23/2006 4:14 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | If you are thinking about going with a new rear axel, drive shaft and five speed tranny, there is a 12 bolt posi with 3.42 gears in the swapmeet, with 6 lug bolt pattern- so you could use your stock rims, and it appears to be the same width as the original axel in my '51.
#59462 04/24/2006 4:13 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | It seems to me that Jeg's and/or Summit sells the different ratio rear end gears for the older rear ends. I think they are a lot cheaper to. | | |
