0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
#594494 11/22/2009 4:04 AM
I've got a 53 GMC with a 228. Number 3 cylinder went down. I pulled the head and piston out and number 3 looks good, but found a piece of metal which is a part to what....on top of number 4. Pulled the #4 piston and it all looks good. I am posting a link to see if anyone can identify the part found on top of #4. Any ideas? The piece is about the size of a dime.
http://rides.webshots.com/album/575627503AxGkrc
The best things in life are FREE!
it appears to be a piece of the valve. I'd pull the valve cover and take a look at #4 valve spring/area.
A piece out of a valve should be pretty evident with the head off. Or are the valves beat beyond recognition? If not,my guess would be that at some point in time someone dropped something down the carb and it finally bounced loose and got sucked into the cylinder.
The valves have no evidence of damage.
53jimmy,
It's hard to tell from the photo what size that thing is. For it to find its way into the cylinder from outside, it has to be small enough to fit through a intake valve....that's not much room.
It's not a throttle plate or a choke plate is it?
Stuart
Is your carb missing a butterfly? headscratch
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Apprentice
Apprentice
Looks to me to be the remains of a bottle cap.
Is it steel (magnetic)? Is it folded?
Crazy, man!
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
In the old days , when You bought stuff like brake fluid it was in a tin can and had a cap pressed into the top under the screw cap that You could take a screwdriver and punch it out or pry the thing off from the edge looks like one of those .Why do I remember that mabe it's the age.
Pete
I think we have a winner with Pete52. probably some engine additive that came in a similar can.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
