| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | I've got a 53 GMC with a 228. Number 3 cylinder went down. I pulled the head and piston out and number 3 looks good, but found a piece of metal which is a part to what....on top of number 4. Pulled the #4 piston and it all looks good. I am posting a link to see if anyone can identify the part found on top of #4. Any ideas? The piece is about the size of a dime. http://rides.webshots.com/album/575627503AxGkrc
The best things in life are FREE!
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | it appears to be a piece of the valve. I'd pull the valve cover and take a look at #4 valve spring/area. | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | A piece out of a valve should be pretty evident with the head off. Or are the valves beat beyond recognition? If not,my guess would be that at some point in time someone dropped something down the carb and it finally bounced loose and got sucked into the cylinder. | | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | The valves have no evidence of damage.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 53jimmy,
It's hard to tell from the photo what size that thing is. For it to find its way into the cylinder from outside, it has to be small enough to fit through a intake valve....that's not much room.
It's not a throttle plate or a choke plate is it?
Stuart | | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | Is your carb missing a butterfly?  | | | | | Joined: Mar 2009 Posts: 25 Apprentice | | Apprentice Joined: Mar 2009 Posts: 25 | Looks to me to be the remains of a bottle cap.
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Is it steel (magnetic)? Is it folded? Crazy, man! If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | In the old days , when You bought stuff like brake fluid it was in a tin can and had a cap pressed into the top under the screw cap that You could take a screwdriver and punch it out or pry the thing off from the edge looks like one of those .Why do I remember that mabe it's the age.
Pete | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I think we have a winner with Pete52. probably some engine additive that came in a similar can. | | |
