0 members (),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Ok guys, what is the easiest way to get the rivets out of the grill? I am going to have to replace the upright pieces, both ends are rusted out. So I don't have to worry about saving them.Thanks Eric | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Should be able to drill most of them, if not use a die grinder. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When I took Mine apart to fix I used a 1/4 inch drill bit and it worked good the rivets are 1/4 inch when I put Mine back together I used 1/4 X 3/8 long screws
Pete | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Drill them out and then go to McMaster.com or somewhere else and buy stainless steel pan head screws with nuts and lockwashers. Easy to take apart in the future. | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Thanks guys. I got it apart, wow there are a lot of rivets to drill out. Now all I have to do is blast it to get rid of 50 plus years of crud. Thanks for the replies. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I just wanted suggest that it might be easier to use "pop" rivets instead of screws. You can get the short aluminum rivets and its faster. | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Well I got the grill all blasted Webshots also added some more pictures and captions to my webshots. | | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | One little side note, the bars will only go in a specific spot. There are notches on the back side of each bar that note it's location and corresponding notches on the back bars.
It took me 5 grills to get enough pieces to make one when I first put the truck together.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
