2 members (moparguy, Wayne67vert), 78 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
#592237 11/13/2009 10:45 PM
Ok guys, what is the easiest way to get the rivets out of the grill? I am going to have to replace the upright pieces, both ends are rusted out. So I don't have to worry about saving them.Thanks Eric
Y
Y Offline
Should be able to drill most of them, if not use a die grinder.
Dremel tool works nice.
When I took Mine apart to fix I used a 1/4 inch drill bit and it worked good the rivets are 1/4 inch when I put Mine back together I used 1/4 X 3/8 long screws
Pete
Drill them out and then go to McMaster.com or somewhere else and buy stainless steel pan head screws with nuts and lockwashers. Easy to take apart in the future.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Thanks guys. I got it apart, wow there are a lot of rivets to drill out. Now all I have to do is blast it to get rid of 50 plus years of crud. Thanks for the replies.
Y
Y Offline
I just wanted suggest that it might be easier to use "pop" rivets instead of screws. You can get the short aluminum rivets and its faster.
Well I got the grill all blasted Webshots also added some more pictures and captions to my webshots.
One little side note, the bars will only go in a specific spot. There are notches on the back side of each bar that note it's location and corresponding notches on the back bars.
It took me 5 grills to get enough pieces to make one when I first put the truck together.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
