7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy), 67 guests, and 3 robots.
Topics128,130
Posts1,056,713
Members48,454
#587957 10/30/2009 12:35 PM
Hi!
New chevy owner from northern Sweden here.
I recently became an owner of an old Chevrolet truck, that have been rebuilt into a Tractor by a farmer at some time, a so called Doodlebug, or EPA-tractor as they are called here in Sweden.
But I would need some help to ID the truck, since I don´t know much about it.
I only know that it is made between 1941-46 and that it is a 3/4 ton or bigger.
[img]http://farm3.static.flickr.com/2515/3833622464_bac51661c7_b.jpg[/img]
The only ID tag I found (on the right side of the cowl under the hood) said:
Manufactured by Chevrolet division Car no: KDS 59.
Are there any more numbers I can find somewhere that can help me identify it?
Thankfull for help!
PS. don´t mind the Ford hood on it right now:P
Best regards/
Magnus, Sweden.
24601
Hi Magnus and welcome to the Stovebolt Page! We have some other Swedes on the site so you have some friends here already!
Wow... they didn't leave you a whole lot to work with, did they?
What's there appears to be solid, though wink
If it has an engine, and the engine is original to the truck, then the engine number will tell us a few things. Look for the distributor. Right behind the distributor is a flat surface (where the dist shaft goes into the engine). On that flat surface should be the stamped engine number.
Also, to the front of the distributor and low on the block will be some casting numbers -- if you can tell us what those are, we can probably tell you more. At least what the engine is, anyway.
What are your plans for the truck? Looks like it would be fun to cruise around in just like it is (well, with tires and a seat... wink )
Tack och välkomna!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Welcome to the Bolt magnus. Yep, looks like you got yourself a nice little doodlebug.... and you can always use that Ferd hood to go sledding on smile
Follow John's advice and you will definitely get some answers. I would even suggest maybe posting it in the General Truck forum for more exposure and answers.
Good luck and thanks for the pictures. Keep us posted.
Thanks for the warm welcome:)
Yes, it need a lot of work before I can get it running again, and there are some rust that needs to be welded, but everything needed is there.
Thanks for the information on the location of the engine numbers. I will look them up, and see if I can find some more information on the truck here:)
My plans for the truck right now, is to renovate it as a Doodlebug tractor. I am trying to track down the former owner of the truck (I got it from a junkyard) and se if I can get some more information about it from him to, maybe when and who that rebuilt it into a tractor.
Best regards/
Magnus
Welcome to the bolt magnus...Looks like you have a bit of work ahead of you...are chevy parts readily available in sweden?I hope so...cool project tho
Hi Magnus. I had never seen a Doodlebug before. I really like it. Looks like it has paid its dues by doing a lot of good work for people and deserves some tender loving care. I sure agree with your plan to restore it as a Doodlebug and saving a piece of history. I look forward to seeing the Doodlebug again when you have fixed it up.
Stovebolts are good for the heart
Leo Offline
Moderator
Moderator
Welcome Magnus, hopefully you can get what you need to get her back together.
Leo
Hi Magnus, welcome from another 'Eurobolter'
You've got some work to do,but the guys (and gals) here will steer you in the right direction!
Jock thumbs_up
More pix on Flickr.
Hej Magnus,
Looks like you've got some work ahead of you! I can just picture what the dudes at besiktningen would say about its current condition. But anything is possible with a little creativity.
I am down around Skaraborg, I fear it is a little distant to be of much support. I've got relations in Skellefteå. Northern Sweden is a large area, what part is yours?
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Apprentice
Apprentice
Hey new Swede Guy, wow, I dig the 40something truck, but like the man said, not much there. It makes me feel somewhat better about mine. I thought missing brackets and emblems was a drag. Luckily you, like me, stumbled onto the best sight to find help...and great people who LOVE old trucks. welcome, Smileychick
1959 GMC 1/2-Ton Stepside
More pix on Photobucket
Welcome to the 'bolt Magnus.
Hi again everyone, and thank you for your warm welcome here:)
Here comes a little update.
I found this engine number on the old chevy:
[IMG]http://i108.photobucket.com/albums/n27/Sid_020/Dsc01137.jpg[/IMG]
It seems that it have an older number to, that have been stamped over, and a new one been added!? Maybe it have been rebuilt/renovated at some time?
And I have more news to!
Since I posted my chevy find at a local webpage, an older man wrote to me and wondered if I wanted to have another old Chevy doodlebug.
It turned out to be a chevrolet of a newer model, that his father rebuilt into a tractor during the mid 1960:s, and was in use to the late 1970:s.
The engine was renovated in the late 1960:s so it is very good, and should be able to get running with little trouble.
Here is a pic from were it stood:
[img]http://farm4.static.flickr.com/3567/3489667286_90a4a5c279_b.jpg[/img]
Here is a pic from when I picked it up:)
[img]http://farm3.static.flickr.com/2663/4117257331_61f3752526_b.jpg[/img]
Here is this chevy´s engine number, and data plate.
[IMG]http://i108.photobucket.com/albums/n27/Sid_020/DSC03758.jpg[/IMG]
[IMG]http://i108.photobucket.com/albums/n27/Sid_020/Dsc01133.jpg[/IMG]
If anyone know anything about these cars, I´ll be thankfull.
Best regards/
Magnus
V
V Offline
Magnus
Welcome Magnus, you couldn't have come to a better site to help with your project. This site holds all the knowledge and experience from fellow bolters who will help in any way they can.
http://www.classyauto.com/v/Chevrolet+3100/Highlander+Woody/56359
V
V Offline
Oops! I forgot to mention. The classy auto link at the bottom of the above post shows a very unique and rare woody chevrolet highlander. When I looked at the photo of your truck I immediately thought! hey you got the beginning of one of these woodies. I[m sure thats not what you have in mind for your truck, but wouldn't it be a cool project! Providing you can work with wood, the fabrication of wood parts would make it more economical. This link was originally posted by another bolter a few weeks back. Anyhow just a thought.http://www.classyauto.com/v/Chevrolet+3100/Highlander+Woody/56359
