Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (3B, JW51, TexasA&M48Truck, baldeagle, Jon G, 3800GUY, cmayna), 31 guests, and 0 robots.
Topics128,004
Posts1,055,252
Members48,418
#58785 04/05/2006 3:54 AM
I
I Offline
What is it that almost everyone has against the Huck braking system? We have run grain trucks using them ,for years and never had any trouble with them. I dont understand the problem.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#58786 04/05/2006 4:32 AM
3B Online: Content
3 Online: Content
Hy iowa trucks
59, It's just that the huck brakes are not self-energizing thereby they require more presure from your foot to stop, bendix brakes are much more operator friendly.
#58787 04/05/2006 1:09 PM
I
I Offline
Ok then the trouble isnt the brakes, its the lack of a hydo-vac. Our grain trucks all had the them. I guess maybe I could see its harder with a pick up.
Jeff
1953 3/4-ton
#58788 04/05/2006 3:31 PM
I don't have a problem with them.
Well, except for finding rear drums for my 3/4 ton.
Aside from that...
#58789 04/05/2006 6:44 PM
Personally, I really can't tell a difference between my 50 1/2 ton and 51 1/2 ton. Other than it's a little more of a pain to adjust the 50's brakes.
Bob
#58790 04/05/2006 7:06 PM
iowa,
It's not the hydro-vac that makes the Bendix brakes self energizing it's the very slight rotation of the front shoe that pushes the rear shoe harder against the drum. It can do that because it's not anchored or pinned at the bottom like the Hucks....or something like that. There has been some other threads on here about that - and folks have converted their Hucks to Bendix-style brakes. I like Huck brakes myself. smile
Professional Novice
#58791 04/05/2006 10:02 PM
Riding in the Passing Lane
I think the Bendix have more stopping power & are much easirer to service.
1972 Chevy c10 Cheyenne Super
#58792 04/05/2006 11:01 PM
Servicing is the biggest factor in Bendix over Huck, I think. I'm still running Huck's though, and no real problems when there properly adjusted. Panic stops aren't fun with either in todays world.
1941 AK named "PETEY" my buddy.
#58793 04/06/2006 2:22 AM
Parts, namely drums! Otherwise I am happy with the Huck style.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#58794 04/06/2006 2:56 AM
Other than the fact you need to manually adjust them, I've never had any real gripes about them. Of coarse I rebuild every brake system on every truck I plan to drive, so there shouldn't be any problems,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#58795 04/06/2006 4:22 AM
I
I Offline
Well the problem with them must be more in the smaller trucks. With the big ones you almost alway have a hydo to do the pushing, by the book, over 30% less effort. I've never found adjusting them to be any thing by easy. Just follow the instrutions in the manual and its a cinch. As far as fixing them, I beleive that I could do a set of hucks in about half the time of the bendix one, seems to be a lot less parts and things that move. The rear hucks are the best. I wish they would have put the ratchet wheel things on the front ones. I hate using the spooon tool to just the fronts.
Has any one ever tried to put the hydo on a smaller truck, like a 3/4 or tonner? Should be a fairly easy thing to do.
Jeff
1953 3/4-ton
#58796 04/06/2006 10:27 PM
The 3/4 & 1 tons used to have a small hydro booster as an option but they were very sensetive.One off of a big truck would put you on the windshield. I would convert to a more modern power brake system.
#58797 04/15/2006 9:09 PM
Junior Member
Junior Member
Has anyone chanced to bendix on a 3/4 ton I have a 52 GMC I'm puting disc on the front and adding power brakes
#58798 04/16/2006 5:00 AM
At least one person has made the swap from huck to bendix. They did a write-up of the process.
Not sure what size truck they had.
Check out the tech tips.
#58799 04/16/2006 5:46 PM
I
I Offline
I dont know about the GMC trucks, but it was my understanding that the Chevys all went to Bendix systems in 51. I would think that the GMC followed and your 52 should already have them.
I noticed in my truck manuals, that a lot of other companies used the bendix system long before Chevy did. I cant find any other maker that used the Hucks other than Chevy. This make me wonder if Huck was owned by GM, or if it went out of business, at the end of 1950.
Jeff
1953 3/4-ton
#58800 04/16/2006 9:39 PM
Junior Member
Junior Member
My 52 3/4 ton GMC has Huck brakes so GMC changed some time after 52
#58801 04/17/2006 6:57 PM
1950 was the last year for Huck brakes on 1/2 tons. 1952 was the last year for Huck brakes on 3/4 ton and 1 ton trucks. This applied to both chevrolet and GMC.
1936 GMC T-14 1/2-Ton Pickup
