1 members (klhansen),
160
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Ready to finish my oak bed on my truck. I am interested in a natural finish. What product did you use? How durable has it been. Let me know.
Tom
48 Chevy 3100 Shortbox 5 window "The Big Dog"
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Minwax natural stain, minwax spar urathane 6 coats.....6 months ago...Check out Mar-k's webside for comparisons of different finishes...They leave samples up on the roof for a year or two and compare the "damage"..... | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used Minwax "Helmsman" clear on mine, UV resistant and for marine environments ...it scored high in Mar K's test. So far so good on my 52. Tim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Same here, What Radial said!!! | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Same here, What Radial said!!! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | My wife has some fluffy pink "blanket" that can't be used as a blanket on my bed. Oh wait, you're talking about the truck. I haven't done mine yet. | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Radial How's the yellowing? Where do you get it? Thanks for your help.
Tom
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | We still have the 2005 test samples out in the weather, but all have failed except the black painted boards. The "final" results were printed a couple years ago, http://www.mar-k.com/final_summary.html , for a brief analysis of what we observed. If you compare these results to the test done in 2004, there is a noticeable improvement and we believe it is due to using two coatings on these test samples, a durable primer/sealer type coating, and then a UV resistant topcoat product. Helmsman by itself failed earlier than Helmsman over another product such as Pelucid or epoxy. The black painted boards are looking great after 4 years in the weather 24/7. We attribute that durability to the POR 15 applied under the gloss black topcoat. The Behr black in the 2004 test was coated over Behr primer and failed early. Mar-Ktech | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Tom, So far no yellowing, but then again I keep my 52 inside the shop. Helmsman is available at Walmart and most any place that carries Min-Wax products. Tim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tom, if you put several coats of Helmsman on it your good to go... BUT most of the time the cracking or looking bad will start at the ends of the boards as they soak up the moisture. Tim once mentioned how it stood his boards up in a pan of it and let the ends soak up all they could. This may be a key to less work later on down the road...... Right Tim!!
EDIT: Mine lasted 8 years with the back of the bed exposed to some sun and even some rain that "blew in" on it. It still looked "good" but I took them out and redid them just "because"!!! Like Tim, I keep my inside most of the time but it sees its days in the sun and even its share of rain now and then! Just put on at least 4 coats.
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | I am surprized that no one seems to have mentioned Marine Spar Varnish that is recommended for boats. This stuff has been around for years and is well proven. Has a lot of natural ingrediences. I am not ready yet for my bed boards put this will be my choice. I know of a friend who has a 53, he has had his varnished since 2000, still looks very good. (6 coats) Ayone who wants a natural clear finish will also benefit from the natural hew that all woods developp over time. This just an example. Click on site below to check it out. http://www.jamestowndistributors.co...p;familyName=Circa+1850+Exterior+Varnish | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... SPAR is the magic word here. That is the ingredient that will let the finish expand/contract without breaking or cracking, which is what lets moisture in and ...well, you know the rest. Perhaps I should have said Helmsman SPAR urethane. At that point I guess its the % of concentrations that probably makes one "More better" than the other. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup Alvin, here is what I did with my Hickory boards. I used several simple aluminum Bread pans ya buy to cook in ..they have 3" sides an was wide enough for each board, to reduce the amount of finish needed.IM GETTIN BETTER AT THIS OR CHEAPER YOU PICK..lol. I put 1/4" of finish in each pan an stood each board in them over night on its end to soak up as much finsh as it could. Just wrap it with plastic wrap after ya immerse to keep the air out. next mornin wipe off the excess to a dry point ..an flip an repeat. now ya KNOW your end grain is saturated with finish, then proceede with at minimun 4 coats of Helmsman ..I personally did 6..to get the DEPTH I wanted in the finish ...FOLKS JUST SAY WOW ..AN WANT TO TOUCH IT ...lol My Hickory should last longer than I do!! Tim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I used Helmsman Spar Uerathane on mine. Truck is used as a daily driver, rain or shine. The finish os holding up very well. Most sites suggest 2 coats. I talked to my cousins husband, who is a woodworker/house remodeller, he told me no less that 8 coats, sanding between coats, for best protection. I went with 9, just because I still had some in the can, plus 2 base coats fo Minwax stain/sealer. I also wax the finish after washings, using the same wax that i use on the paint. That has worked very well for me keeping water out and preventing stains. Also makes it very easy to keep clean.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | No matter what varnish product you use, you're going to have to plan on sanding and refinishing it on a regular basis. I used a wide range of product on sailboat brightwork over a course of years, and the best that I got out of any was about a year and a half. The sun and weather just breaks the coating down, no matter what additive you have in the mix. Ironically, it is often the most expensice coating that fails first! The Helmsman UV resistand coating began to crack and peel after 10 months. Sikkens, who are supposedly one of the top finishes, shows wear and tear after a year. Varnish is just not a good finish for a truck bed. That's why they used the black paint! A working truck for the working man. | | |
