4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 125 guests, and 1 robot.
Topics128,109
Posts1,056,271
Members48,439
#582130 10/10/2009 7:21 PM
what is the best aftermarket carbrator to put on a 235 just for a daily driver
The best, would probably be the factory original one, but lots of others carbs would work fine. You can rebuild yours or buy a rebuilt one from Chevs of the 40s, may be the way to go if you want to keep thing original. Also Langdon's stovebolt has more modern carb adaptable to your motor.
I like Langdon's Holley-Weber mainly as it's modern vs 50 years old with worn out body etc etc. Check out his web site www.stoveboltengineco.com
And best of luck
Jim
1946 1/2-Ton Chevy
thanks i have read a lot on here about the old rochesters leaking i guss thats ok if your not driveing alot but i plan on building a driver i also have thought about useing a diffrent intake and header to help it breath a little better maybe help milage a little also do you have any ideas on that
I replaced my original Rochester B with a reman unit - lifetime guarantee - it cost an arm & a leg, but it doesn't leak & the truck runs like a top.
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
