5 members (lc_btv, Oldcaliforniakid, Jay R, Rexville48, Hugh63c10), 82 guests, and 3 robots.
Topics128,050
Posts1,055,673
#580337 10/04/2009 2:08 PM
Hi All, Starting to reassemble the 46. Not sure which hole the speedometer cable should go through. Didn't have one when I bought it.
I don't know this one but I would think there should be a larger hole (for the knurled nut on the cable that attaches the cable to the speedometer) in the firewall inline and alittle lower than the back of the speedometer . If the speedometer is out of the dash just look through the opening in the dash and ya should get a pretty good idea of which one it is .
... its probably the biggest hole on the driver side. When ordering some parts order the rubber grommet for the firewall and you have it.
You can see the hole in the pics of my 46, it's above and just to drivers side of the rocker cover. Big rubber grommet that carries other wire or wires also.
1946 1/2-Ton Chevy
