| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 10 New Guy | | New Guy Joined: Nov 2006 Posts: 10 | Hi All, Starting to reassemble the 46. Not sure which hole the speedometer cable should go through. Didn't have one when I bought it. Thanks | | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I don't know this one but I would think there should be a larger hole (for the knurled nut on the cable that attaches the cable to the speedometer) in the firewall inline and alittle lower than the back of the speedometer . If the speedometer is out of the dash just look through the opening in the dash and ya should get a pretty good idea of which one it is . | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... its probably the biggest hole on the driver side. When ordering some parts order the rubber grommet for the firewall and you have it. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You can see the hole in the pics of my 46, it's above and just to drivers side of the rocker cover. Big rubber grommet that carries other wire or wires also. | | |
